Ping Lozzo
Discussion in 'UK Motorcycles' started by Simon Wilson, Jul 13, 2009.
  1. Simon Wilson
    Simon Wilson Guest
  2. Simon Wilson
    Piece of piss.
    Make sure you get the brackets that locate under the fuel tank, or
    you'll have to make your own out of bits of Pip's left over car stereo
    fitting brackets.
    I fitted mine in about an hour from scratch. Leave the fairing all
    bolted together and with the bracket in place. Put the bike on the
    centre stand with the front wheel in the straight ahead position. You
    simply remove the original headlight/indicators and associated
    brackets, leave the wiring as it is and then bolt the fairing complete
    into the frame, plug the wiring up to the new headlight and indicators
    and cable tie it where needed, then fit the backets under the tank to
    the fairing... simple as that.
    My bike had aftermarket headlight brackets, so you may need to remove
    the top yoke to remove yours from the bike. I paid 60 quid for my
    fairing complete on ebay, but I got very lucky.
    Lozzo, Jul 13, 2009
  3. Simon Wilson
    Simon Wilson Guest
    Thanks.
    <fires up ezsniper>
    Simon Wilson, Jul 14, 2009
