Ping Lozzo
Discussion in 'UK Motorcycles' started by M J Carley, Oct 22, 2008.
  1. M J Carley
    M J Carley Guest
    What oil filter did you or Biz put on that VFR750K? The one that's
    there is not the same size as the one David Silver has sold me.
  2. M J Carley
    I'm sorry, I haven't a clue because I didn't buy it, Biz did, but I
    remember it being the same size as the one that came off. The pattern
    part number for the one you need is SF4005 and that covers all VFR750s
    from the FJ model up to the FV and the VFR800i. I'm pretty sure no
    other Honda filter will fit properly. As long as the diameter is
    correct it should be ok, because from memory the other Honda options
    are either too large or too small in diameter to go on properly.
    Some pattern filters are shorter or longer in length than others.
    Lozzo, Oct 22, 2008
  3. M J Carley
    M J Carley Guest
    This one's wider. I have Honda filters and the tool for fitting them
    and the tool doesn't fit the filter that's on the bike. I don't want
    to take it off until I know I have one to replace it because, at
    worst, I can always change the oil and leave the filter on for a bit
    longer.
    M J Carley, Oct 23, 2008
