Ping malc - damping follow-up.
Discussion in 'UK Motorcycles' started by Krusty, Sep 21, 2010.
  1. Krusty
    You know your harsh forks? Raptors have the same problem, the forums
    are full of people bitching about it & asking what other
    forks/internals fit etc etc. I noticed it on mine too, fine on 'soft'
    bumps & wallows but the initial compression on things like the edges of
    small potholes is enough to knock your teeth out.
    I've also noticed the riding position felt a bit weird after riding
    another bike, but that's normal when swapping from a completely
    different style of bike (MV or Tiger). However on Saturday I was out
    with L on her SV, & we swapped for a while, & that felt weird too,
    which it shouldn't do as it's so similar to the Raptor. It felt like
    the forks were twisted - & the lightbulb over my head went 'ding!'.
    Sure enough, a bit of careful measuring showed the SV's forks were
    fine, but the Raptor's were twisted. I loosened the clamps & wiggled
    things about to get them straight, torqued it all up again, & they're
    now *much* less harsh.
    I don't know how they got twisted in the first place as I've had them
    out previously to change the oil & I'm sure I lined everything up
    properly when I stuck them back in. I'm wondering if tightening the
    screw-in front axle when I put the wheel back in caused it. The fork
    clamp bolts are only 23Nm so it wouldn't take much to twist them a bit,
    given the leverage involved when doing things at the bottom end of the
    legs. It would explain why so many Raptor owners mention it, but none
    of the original road tests do.
    Anyway just thought I'd mention it in case your bike has the same issue.
  2. Krusty
    malc Guest
    Good call, I'd not even thought about that (knowing nothing about suspension
    on bikes). I'll check at the weekend.
    Thanks
    Malc
    Rusted and ropy.
    Dog-eared old copy.
    Vintage and classic,
    or just plain Jurassic:
    all words to describe me.
    malc, Sep 21, 2010
