Ping TBC - airflow stuff.
Discussion in 'UK Motorcycles' started by Krusty, Jul 21, 2010.
  1. Krusty
    I was reading some interesting stuff last night on a bloke's attempts
    to modify an airbox based on resonance & pressure calcs. I'd be
    interested in your thoughts on why he failed miserably! The relevant
    pages are the four with 'airbox' in the title at the top of
    http://homepage.mac.com/rg500delta/TL1000/Randys TL1000S page.html
    and the 'Dyno testing spring 2007' link for the final dyno results.
    It makes interesting reading for anyone else who's bored.
  2. Krusty
    I think I'd have to be far more bored than I am currently, TBH.
    CT, Jul 21, 2010
  3. Krusty
    M J Carley Guest
    At first glance, I would think it's because he thinks you `tune' the
    airbox to give you a pressure boost (on the intake stroke) but he
    doesn't seem to know about the spread of frequency on that boost or on
    the effect at other frequencies. Depending on how you do it, you can
    have a high boost over a very narrow range of engine speeds, so that
    the boost is practically useless or a lower boost but spread out
    around some centre frequency. You also have to take into account the
    fact that there will be more than one resonant frequency and some of
    the other ones may lie in the operating range of the engine and cock
    up the response at certain speeds.
    I don't know what he means by `fully mapped'. Does that mean he has
    remapped with some available map, or has be remapped taking account of
    what he has done to the airbox?
    M J Carley, Jul 21, 2010
  4. Krusty
    That did seem to be the conclusion he came to. I.e. a noticeable boost
    would be in such a narrow range that ram-air would be a much better
    option.
    Ah, don't think he mentioned that at all.
    Remapped on a dyno to get the right mixture at all revs & throttle
    positions.
    I suppose the real question is why a bigger airbox resulted in less
    power? Shortening the throttle bodies to increase power at higher revs
    is valid afaik (it's what MV do with their variable length intake
    trickery), so to get less power after doing that & increasing the
    airbox size seems a bit strange. The shape of the airbox screwing
    things up with turbulance maybe?
  5. Krusty
    M J Carley Guest
    It might be because the shape of the airbox changed the acoustic
    response at the intakes. In other words, there was a boost in pressure
    but it wasn't at the same place as the holes in the airbox.
  6. Krusty
    That's not necessarily true, especially in these days of emissions &
    noise regs. There are some very well proven mods that can make a huge
    difference (opening the 2nd pre-chamber on 885 Tigers[1], cutting a
    hole in the top of DRZs, removing a chunk from the bottom on TL1000s).
    The problem comes when people do that but don't sort the fueling to
    match.
    Which almost certainly means it was running lean as he hadn't rejetted
    it.
    [1] This gave an extra 15bhp on mine after jetting.
  7. So true. Applicable also to exhaust systems, carburettors, FI systems,
    and loads of other things too.
    Oh, and cam timing: "If you change the cam timing by one tooth, you get
    an extra 10bhp, you know! They make it the way they do for emissions
    reasons. My mate did this and..." etc etc etc.
    Suspension tends to remain an area where it's quite easy to improve on
    the standard product.
    The Older Gentleman, Jul 21, 2010
  8. Krusty
    Makes sense. Would it be easier to design an airbox for an in-line 4 as
    you can shape it to give a smooth flow to the back where all 4 throttle
    bodies are sat next to each other? I'd guess that would be harder to
    achieve with a V-twin where one throttle body's at the front of the
    airbox & t'other's at the back.
  9. Krusty
    Where the mods are more to do with improving the quality of materials than
    changing the laws of physics.
    Seats are another area where great improvements over stock items can be
    made. WTF can't makers provide comfy seats in the first place?
    wessie, Jul 21, 2010
  10. Krusty
    I'm not really sure how you can say that given that pretty much every
    bike on the planet will make more power throughout the rev range when
    fitted with an aftermarket exhaust & re-jetted/mapped to suit.
    If you're talking about people who just drill holes in the standard
    exhaust & do nothing to the fueling, then yeah.
  11. Krusty
    Oh christ yes. Some of them do it to get more dosh when you buy the
    'comfort seat' option, but not all manufacturers even offer that.
  12. Krusty
    crn Guest
    DING.
    I fixed the totally hopeless bloo 400/4 by grabbing an airbox cover
    from ebay for a quid. Some previous owner had probably just lost it.
    crn, Jul 21, 2010
  13. Oh, yes, yes, yes. And some manufacturers (hello, BMW) even have the
    temerity to offer 'comfort' seats as a pay-extra option.
  14. Well, I was thinking that way, yes. Should have phrased it better.
  15. Result. I think the last one I flogged fetched a fiver :)
    There again, you've had a few bits off me for nowt, you lucky little
    chappie.
  16. Krusty
    SIRPip Guest
    There's always a case in point: the Bandit 1200, for example. Jetted
    to run too rich as standard, you can fit a race can and do nothing else
    and expect to see up to 10bhp for your trouble. It won't lean out at
    high revs, either. Or you can fit a K&N and see up to 5bhp and a chunk
    more torque to boot. Do both without jetting and you're in trouble, so
    they say - but do them both, fit a Stage II Dynojet and drill the
    dreaded 25mm hole in the airbox and you're way above standard power
    without doing anything technical or costing the earth.
    SIRPip, Jul 21, 2010
  17. Krusty
    Catman Guest
    The factory engineers are aiming at different sets of results, including
    fuel consumption, ability to run over a wide range of atmospheric
    conditions and altitudes, noise, cost etc etc.
    After market exhaust systems are hardly cheap, much of that cost being
    research related I expect.
    Well, yes.
    www.cuore-sportivo.co.uk
    Catman, Jul 21, 2010
