Pink grease with new brake seals
Discussion in 'UK Motorcycles' started by Spike, Dec 10, 2005.
  1. Spike
    Spike Guest
    As subject really... Mr Fowlers delivered a new set of front brake caliper
    piston seals this morning.. £80 for a complete set, I ask you!
    Anyway, rants about OEM parts aside, each seal kit comes with a very nice
    sachet of pink grease. So where is this sposed to go then? No mention of
    it at all in the manual, and its a genuine Yamaha one, not a HBOL...
    Guidance please people...
    Spike, Dec 10, 2005
  2. On the surface of the pads......
    The Older Gentleman, Dec 10, 2005
  3. Spike
    Smear lightly on the pistons before fitting - it's for lubricating the
    piston/seal interface.
    I have an old tube of Girling brake grease that has lasted me decades of
    brake cylinder rebuilds.
    sweller, Dec 10, 2005
  4. Spike
    sweller said...
    I bought some Wurth brake grease when I cleaned and fitted new pads to
    the APs on the Gixer. It comes in little sachets and one of those was
    enough for both calipers when applied with a toothbrush. AP specifically
    say not to use coppa-slip or the like on their calipers.
    Lozzo, Dec 10, 2005
  5. Spike
    Cab Guest
    Shouldn't that be a light coating of WD40?
    Cab, Dec 10, 2005
  6. Spike
    Molly Guest
    Any idea why? I've always used the copper type grease on brakes.
    Molly, Dec 10, 2005
  7. Spike
    Molly said...
    They don't say, but I figured they said it for a good reason, so I
    complied.
    Lozzo, Dec 10, 2005
  8. Spike
    scruttocks Guest
    Molly wrote:
    snip
    Copper and aluminium in cobination with an electrolyte like salt water
    results in galvanic corrosion, there is a potential of about 2 volts
    between them. Anodising and the grease in the coppa-slip tends to stop
    it happening though.
    scruttocks, Dec 10, 2005
  9. Spike
    Depends where you're putting it. Brake fluid parts bad, sliding parts
    (pins, pad shims etc) good.
    IMO.
  10. Spike
    sweller said...
    I used coppa-slip for years, but I will invest in a small tin of Morris
    Brake Grease next week instead.
    Lozzo, Dec 10, 2005
  11. Spike
    Brake grease is for pistons: to lubricate the seal/pistons. I wouldn't
    put it on pads or pins; copper based grease for that.
  12. Spike
    sweller said...
    It was the pads and pins they said not to use coppa-slip on. PFM Brakes
    recommend the use of silicone RTV on the back of the pads.
    Lozzo, Dec 10, 2005
  13. Spike
    Blimey. Live and learn.
  14. Spike
    sweller said...
    I learnt a bit too. I'll monitor the calipers and see how it affects
    them and how long the brake grease lasts before it needs cleaning off
    and redoing again.
    Lozzo, Dec 10, 2005
  15. Spike
    I really don't think you did. There's no such product.
    I've used Copaslip and its near relative Copper Ease, but I've never
    seen coppa-slip on a shelf anywhere.
    Pip, Dec 10, 2005
  16. Spike
    Pip said...
    Fucking pedants.
    I have the same tin of Comma Copper Grease that I have had for many
    years.
    Lozzo, Dec 10, 2005
  17. Spike
    I can't be arsed to go and look in the garage or in my van but I'm
    sure I've got around 5 different types of spray on copper shit. They
    all work equally well apart from in freezing cold weather when all you
    get is a jet of propellant and no fucking copper.
    Did we try to burn any copper**** at Donington when we were emptying
    my van of aerosol pyrotechnics?
    Andy Bonwick, Dec 10, 2005
  18. Spike
  19. Spike
  20. Spike
    I said this sort of thing ages ago, but there you go...
    Muck, Dec 10, 2005
