Pissing weather & drying laptops
Discussion in 'UK Motorcycles' started by Ace, Jun 19, 2006.
  1. Ace
    Christofire Guest
    The last laptop I got wet (spilt a G+T over it) was a case of open it
    up, let it dry, reassemble. It took two days to get it right as the
    keyboard membrane had got wet, and needed to be cleaned twice before it
    worked properly again.
    I wouldn't recommend trying to drain it - the laptop I took apart had
    electronics (including capacitors) around the display. I'd unscrew the
    lid screws, take the back off and leave it flat to dry.
    However, if it's just a bit of damp between the display and an outer
    protective layer you might be able to take the front bezel off, the
    layer may fall out, leaving you a minute's job with a clean, dry cloth.
    No promises though.
    Christofire, Jun 19, 2006
  2. Ace
    Cane Guest
    OMG!!!11!!! PMSL!!!!!111!!
    Cane, Jun 19, 2006
  3. Ace
    Tried that, but I can't get it fully off, and it doesn't look like an
    outer layer would come loose. And it's definitely wet in at least two
    layers anyway.
    Cheers anyway.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Jun 19, 2006
  4. Ace
    Fr Jack Guest
    Can you lay your hands on some silica gel?
    Cheers!
    Fr Jack
    B12S POTENTIAL LICENCE SHREDDER - AT GRIN FACTOR 10!
    FRJACKUKRM AT GMAIL DOT COM
    Fr Jack, Jun 20, 2006
  5. Fizzy pop noise from the display might convince you otherwise.
    Grimly Curmudgeon, Jun 20, 2006
  6. Ace
    Just in case anyone's interested, I thought I'd update you on this.
    Thanks for the input, but in the end I went with my "leave it turned
    on and just let it dry out under its own heat" approach. Which has
    worked just fine. One of the two layers is now completely cleared,
    with the other one now reduced to just a few spots.
    Nothing went fizz and there's no visual sign of deposits in the
    display, so I'd call that a result.
    _______
    Ace, Jun 21, 2006
