Plastics paint vs repair
Discussion in 'UK Motorcycles' started by TD, Mar 2, 2011.
  1. TD
    TD Guest
    Damaged fairing on a 10 year old red / black busa. Occurs to me that
    on a bike that age new plastic might stick out too much and a good
    paint job might be better.
    Not to be boring but I didn't bin it, just that I saved up some dosh
    and I wouldn't mind fixing the old dog.
    TD, Mar 2, 2011
  2. TD
    TOG@Toil Guest
    New plastic will be pricey. I'd buy the required used panels on eBay,
    get them painted up if necessary, and just clag them on. That way you
    can carry on riding the thing with the damaged panels, whereas if you
    want the old panels repaired, you'll have to send them away and put up
    with a naked 'Busa in the meantime. Which might be fun. Or not.
    And then when you've replaced the old damaged panels, you put them up
    on eBay and recoup much of your investment. Or maybe all, if you're
    lucky. But even if the replacement panels, painted etc, cost you (say)
    £600, and you only get £300 for the old ones, that means you've got
    yourself some nice spanky panels for the same price as someone has
    just paid for some manky ones.
    This approach has worked for me innumerable times.
    TOG@Toil, Mar 2, 2011
  3. TD
    Frooty Guest
    Bear in mind on the red / black 1999 Hayabusa with the 'Candy Antares Red'
    colour scheme you are looking at probably 50% more to paint it in both paint
    cost & labour, as you need the silver base coat before the candy top coat.
    There have been problems matching this colour so it's a bad idea trying to
    paint only a couple of panels, the chance of getting these to match the rest
    of the bike are low, so you'll need to do the whole bike or nowt!
    Frooty
    GSX1300RX - The FAST AS FECK wan
    TT250R - The wee dirty wan
    Lifan LF50QGY - The wee monkey wan
    Down to just three toys :-[
    Frooty, Mar 2, 2011
  4. TD
    zymurgy Guest
    I paid over £100 for a panel from a breaker (via partfinderuk), but
    whilst it was the right colour, it was the wrong year model and didn't
    match up properly, so it went on ebay and fetched about £35.
    So the value of panels can go down as well as up ;-)
    Paul.
    zymurgy, Mar 2, 2011
  5. TD
    There's an immaculate right hand panel and nosecone in blue/white for a
    GSXR1000 K1 sitting in my lock-up. Unfortunately there have been two
    K1s crashed and then broken just for the lack of cheap replacement
    panels recently, and I got there too late with my pair to help out.
    Could have sold them twice over for a fortune if I'd found out sooner.
    Lozzo
    they churn out)
    Lozzo, Mar 2, 2011
  6. TD
    TD Guest
    Oh ****. You mean something like:
    https://picasaweb.google.com/lh/photo/yl6ZP39sKSWApS_I8dkAfw?feat=directlink
    ? I have no fucking idea what colour code it is.
    Can you expand on "problems matching"? I know **** all about paint, I just
    assumed they sprayed the stuff on then lacquered. Which would of course not
    explain how painting can look better than a new panel on an old bike. If
    indeed that is the case.
    Interestingly, nobody's yet said "don't buy a new panel as it will look
    different to the original after 10 years of the original fading".
    FFS, what to do. But I fucking love the bike so for once I don't mind
    splashing some dosh on it.
    TD
    2000 GSX1300RX (red and black)
    Missing: SOB, Unreliable Italian exotica, cage
    - What with the Internet, it doesn't take long to feel like one is an
    - expert on any subject these days.
    TD, Mar 3, 2011
  7. TD
    I assume that is you. Gaylord.
    it's 12 years old. Just fix it up with so that it does not fall apart and
    ride the bloody thing.
    wessie, Mar 3, 2011
  8. I've got similar probs with my VFR. It currently looks like it is
    cheaper to buy a cheap ebay fairing set from China than it is to paint
    my original panels up. Aus$600 compared to Aus$1000 for a paint job.
    I've done about 6 crashed bikes with the Chinese jobbies and most of
    them fitted up quite well after a bit of dremel time.
    Fraser
    Fraser Johnston, Mar 3, 2011
  9. TD
    Candys are different, they use two colours (silver & red in your case),
    & the red is slightly translucent so the silver base coat shows
    through. The thicker the red coat, the darker it will be, which makes
    colour matching very tricky.
    Krusty, Mar 3, 2011
  10. TD
    SIRPip Guest
    It so happens that a young friend of mine (f'naar) has roped me into
    his bike project. He's found a VFR400 (NC30) that has been 'resting'
    in a dry garage for several years, after being dropped. We went over
    there at the weekend and got it started and the motor is sweet, in fact
    all the mechanicals seem to be fine. There's no apparent damage to the
    frame, but the fairing is missing, having been binned years ago. This
    was going to be a bit of a stopper, until he came up with this:
    http://www.k-conversions.co.uk/index.php?main_page=product_info&products
    _id=19
    which looks just the ticket, and he prefers the look of the headlights
    to the standard twin round jobbies. It is almost too good to be true -
    all plastics, lights front and rear for 700 dorra!
    I'm currently pondering the realities of the situation - what does the
    FOAK reckon?
    Apart from the plastics, it obviously needs an MoT and in order to get
    that, will need a pair of tyres as those fitted are a bit smoothish but
    they've cracked at the bott6om, having been allowed to go flat.
    Purchase price, subject to haggling, starts at £350, but I reckon we
    can get him down to a couple of hundred with a bit of nagging - but
    that still leaves a total of about a grand on the road.
    I'm of the opinion that he ought to look elsewhere, but of course he's
    infatuated with the thing and it's all so close. He seems to accept
    he'll never get his money back, he wants to keep it for ever.
    Opinions?
    SIRPip, Mar 3, 2011
  11. TD
    That looks like a Tiger bodykit from Thailand. They are pretty good and
    look the canine's nads when fitted properly and painted up. I've seen a
    few now and they certainly make the old NC30 look much more modern than
    it did
    Lozzo
    they churn out)
    Lozzo, Mar 3, 2011
  12. TD
    Frooty Guest
    I couldn't find a paint code for this scheme, but spoke to a guy called Mal
    Wilkinson at Bike Paints (Google it & you'll get the number), he told me
    about the problems & said he had formulated a colour for touch-ups / paint
    that was as close to the original as you'll find.
    Mine is the early copper / silver scheme & all the panels are at my friendly
    local (& cheap!) sprayer now.
    I looked into the full sets of replacement panels on ebay, they are
    definitely cost-effective, but I wanted the bike to be as original as
    possible (I'm anal that way).
    If you're not bothered about that then go the ebay route but be prepared for
    problems fitting (as others have said), plus they don't have a lot of
    lacquer on them so budget for someone giving them a coat too.
    As TOG says you'll probably get the bulk of your money back selling off the
    original panels.
    Frooty
    Frooty, Mar 3, 2011
  13. TD
    Tyga, you mean?
    ogden, Mar 3, 2011
  14. TD
    zymurgy Guest
    Why don't you get hold of [1] one of Lady Nina's ZXR basket cases. At
    least they've been run in the last 12 months and have fairings ..
    Paul.
    [1] Wrest from her grasp ... ?
    zymurgy, Mar 3, 2011
  15. TD
    Yeah, they made them too :)
    Lozzo
    they churn out)
    Lozzo, Mar 3, 2011
  16. Looks like the Tyga kit. See if he can go direct and buy one cheaper.
    Fraser
    Fraser Johnston, Mar 4, 2011
  17. TD
    SIRPip Guest
    Heh. There's anal, and there's my acquaintance who gets me to buy
    stuff from eBay for him (because he doesn't trust it, doesn't want to
    open an account and would never give his details to Paypal in any case)
    and I tell you, he's really fucking anal.
    We started off with old Hornby railway catalogues (had to be immaculate
    with no creases or loose pages, had to have the price list included),
    moved through Paystation games (had to be the original issue, Platinum
    wasn't any good, even if it was enhanced and updated) and now we're on
    music on CD - which has to be the original issue, so has to be NOS and
    has to be in original unbroken cellophane.
    I'm speechless, but he forks over the cash and it's feedback for
    nothing to me.
    SIRPip, Mar 4, 2011
  18. TD
    SIRPip Guest
    Good call - I'm looking at their site now. He'll be looking to me to
    front the transaction, so I'd best do the research. That's very
    useful, thank you.
    SIRPip, Mar 4, 2011
  19. TD
    SIRPip Guest
    Prise out of her cold, dead hand, more like.
    SIRPip, Mar 4, 2011
  20. TD
    SIRPip Guest
    Thanks for that Loz. I'm on it.
    SIRPip, Mar 4, 2011
