Please help - fuel leak
Discussion in 'Australian Motorcycles' started by James Harvey, Jun 12, 2005.
  1. James Harvey
    James Harvey Guest
    Hi all.
    My mechanical knowledge is limited, but I'd like to hear your thoughts
    on this before I take it to a mechanic.
    I started my bike (94 YZF600) today for the first time in three weeks. A
    few weeks back I changed the oil and filter, and ran out of time and
    left the fairing off. Since then it has rained almost non-stop here in
    Perth so I didn't get round to putting it back on.
    It was a little reluctant to start at first, and stalled. On the second
    attempt it started nicely and ran, but idled a bit lower than normal.
    Then I noticed the smell of fuel. Looking underneath the bike, I could
    see petrol dripping out. When I took off the fairing I could see that it
    was coming from a little metal tube about 8mm in diameter. There is one
    of these tubes directly above each cylinder, angled backward and
    slightly downwards. The fuel seemed to be coming from one of these only.
    A bit of history: once before, this bike spontaneously started leaking
    fuel while I was riding it. I took it to a mechanic who told me that the
    carburettors had been blocked up by dirt and gunk from the fuel, and
    that it had backed up and started leaking. He cleaned it up and all
    seemed well. This was nearly a year ago.
    Again I emphasise my lack of mechanical abilities. What have I done to
    my bike???
    Thanks.
    Bruce.
  2. James Harvey
    Mad-Biker Guest
    Fuel leaks are somethingyou dontmuck around with,
    Just dont light a match to see were its coming from.
    Mad-Biker, Jun 12, 2005
  3. James Harvey
    Stuart Guest
    Hi,
    I don't know anything about your model but I do know something of your
    problem.
    I think you might find the needle in the float bowl of your carby (s)
    is stuck open, most likely from dirt or whatever.
    You need to clean this out and clean the filter , if there is one. If
    there isn't one instal a fuel filter.
    And most likely you need to empty and flush the petrol tank. Maybe water
    and junk has got in and finally built up. ( I had a Yamaha once that was
    full of rust in the petrol tank. Their cheap manufacture encourages such
    problems )
    Maybe the float setting needs to be fixed too. It's not hard, just
    requires getting the specifications, probably some new seals and gaskets
    for the carbys, and remembering ( by writing down ) the order you
    unscrewed things so you can screw them back together again.
    Try it, it's a lot more satisfying to work it out ( and a hundred or so
    dollars cheaper ) than paying.
    Regards
    Stuart
    Stuart, Jun 12, 2005
  4. James Harvey
    James Harvey Guest
    Thanks Stuart!
    That sounds like what they did last time. I will give it a go.
    Bruce.
    James Harvey, Jun 13, 2005
  5. James Harvey
    sharkey Guest
    [I'm assuming this thing isn't EFI, okay?]
    Where do they come out of? The tank? The carbs? Manifolds?
    If it's the carb overflow pipes, probably just a stuck needle valve ...
    sometimes tapping the float bowl with the handle of a screwdriver will
    make the problem go away.
    Got a digital camera? Mail me a photo and I'll tell you what it is!
    Get them to install a fuel filter this time then.
    -----sharks
    sharkey, Jun 14, 2005
