Points ignition and EMP
Discussion in 'UK Motorcycles' started by The Older Gentleman, Jun 2, 2005.
  1. Question for the fizzy-cysts and those who know about electronics.
    Enquiring minds (well, one, anyway: mine) need to know.
    Is electronic ignition proof against a nuclear bomb-generated EMP?
    I assume that modern microprocessor-controlled systems aren't but what
    about older stuff?
    Secondly, is battery & coil points ignition EMP-proof?
  2. The Older Gentleman
    I think that the one system that's proof against a nuke EMP strike, is a
    valve based system. Or, and older type mechanical diesel engine, like
    the 300 TDi in the older Land Rovers. All the modern shit has tiny
    squares silicon making them run.
    Muck, Jun 2, 2005
  3. The Older Gentleman
    Loz H Guest
    Do you know something we don`t?
    The main problem with EMP is equipment that is connected to lengths of
    wiring/metal, where a large current will be induced in such. This is where
    your telly or PC will blow up with them being connected to the mains,
    antennas, telephone wires and so on. It`s not so much the components in the
    equipment being sensitive (excepting your common computer, for example, or
    maybe the more modern telly..), it`s the concentration of the surge itself
    in the wiring that would ensure that anything working on low-level voltages
    will fry. It`s not unreasonable to assume that a battery-powered radio with
    it`s antenna retracted would survive, for example.
    I imagine that points and coils are safe enough no matter what, but AFAIK
    all electronic ignition systems use Field Effect Transistors in the igniter
    at least and these are more sensitive than most components. With the bike
    frame being large enough to induct such currents, I imagine a decent EMP
    would be enough to take them out. One way to help avoid this I suppose would
    be to earth the frame if you`re really worried...
    Out of interest, valve based stuff is literally bombproof in this respect.
    The Ruskies used valves in the avionics of the MiG25, much to the amusement
    of the yanks when they found out. A year or so later, they realised
    why.....
    Loz H, Jun 2, 2005
  4. The Older Gentleman
    TOG Guest
    Loz H wrote:
    To be honest, I think that it used valves because the Russian
    electronics industry was seriously behind the times.
    <heroic Commie voice>
    "Russian microchips! The biggest microchips in the world!"
    </hcv>
    ISTR that the 25 was also mainly built of stainless steel - or was that
    the 23? Not because it was a particularly good idea, but because,
    again, the Russians simply lacked the aircraft alloy technology to make
    something bloody fast that didn't melt unless they used S/S.
    TOG, Jun 2, 2005
  5. New from DeLorean... The Mig 25.
    Grimly Curmudgeon, Jun 2, 2005
  6. Suspect I'd say. The electronic switches used to discharge the
    capacitor into the coil in CDI would probably be subject to stress voltages
    from pickup in the plug lead via the coil and would probably suffer
    punch-through. For transistor-assisted points ignition, the same would
    likely be true for the switching transistor.
    Almost; it'd possibly punch-through the capacitor insulation
    but so long as that didn't make a dead short (and there's a reasonable
    chance the points would be closed at the moment of the pulse anyway) then
    it'd still work for a while, until the points wore out through sparking,
    albeit at the expense of radiating lots of RFI.
    Brunel University. Room 40-1-B12, CERN
    GSX600F, RG250WD. "You Porsche. Me pass!" DoD #484 JKLO# 003, 005
    Dr Ivan D. Reid, Jun 2, 2005
  7. The Older Gentleman
    Chris H Guest
    Aluminium wouldn't have been strong enough at the temperatures generated
    by air friction at Mach 2.5 and they didn't have the titanium processing
    knowledge that was generated by the yanks as part of the 'RS-71'
    programme.
    Iron alloys have higher strength at temp than aluminium alloys at the
    expense of weight.
    There's a good (and very readable) book about the Skunk Works that
    discusses this (briefly).
    http://www.amazon.co.uk/exec/obidos...7131/sr=1-1/ref=sr_1_10_1/026-6774382-0335637
    Highly recommended for all aviation/engineering anoraks.
    Chris H, Jun 3, 2005
  8. Grimly Curmudgeon, Jun 3, 2005
  9. The Older Gentleman
    platypus, Jun 3, 2005
  10. On Thu, 2 Jun 2005 07:49:34 +0100,
    if you're that close to the EMP your dead anyway
    <--ROT13 it
    Spam Trap in Header
    GS850 Trike
    FOR SALE TOUCH SCREEN PC. E MAIL FOR DETAILS
    http://borg.no-ip.com
    ‹(•¿•)› BORG, Jun 3, 2005
  11. Complete and utter bollocks.
    Oh, and Borgie - can you do something about those bloody symbols in your
    posting name? They have to be stripped out before any reply-to can be
    posted.
    The Older Gentleman, Jun 3, 2005
  12. The Older Gentleman
    On Fri, 3 Jun 2005 07:19:47 +0100,
    Rash generalisation. Get a proper computer and decent newsreader.
    Pip, Jun 3, 2005
  13. The Older Gentleman
    Loz H Guest
    <> spewed forth
    the following...
    Not necessarily. Valves don`t really do anything that transistors cannot,
    and the russians certainly had those sussed out by then. Also, consider the
    problems with powering up a load of valve circuitry. All that extra weight
    and extra load upon the electrical system. I don`t think the choice to use
    valves was purely for "backwards technology" reasons...
    Heh. I remember seeing a pic of a Russian clone of a Intel 8086 CPU, I think
    it was. It looked like a bourbon cream biscuit crossed with a spider...
    Yep. Hand welded too. They did use titanium in areas of high heat
    concentration however.
    Loz H, Jun 3, 2005
  14. The Older Gentleman
    Loz H Guest
    Nope. High altitude airbursts are where it`s at if you want to use EMP as a
    weapon. If one was detonated 20 miles or so over the North Sea or Atlantic,
    both of which are close enough to knacker up the National Grid, you probably
    wouldn`t even notice until you went to turn the telly on.
    Loz H, Jun 3, 2005
  15. I was thinking more about an EMP from a Nuke not a specific EMP
    device.
    Reminds me of that story about when the 'West' got a look at the Mig
    25 Flogger for the first time and laughed at the 'backwards' valve
    technology the Russians had built into it, only to have the pilot
    explain that in a nuclear war micro chips would stop working and their
    planes would drop from the sky.[1]
    [1] Not sure how true that is but it did make a few people think. If
    only they knew about Ebay then,
    <--ROT13 it
    Spam Trap in Header
    GS850 Trike
  16. The Older Gentleman
    Just how big is this EMP anyway? Don't many circuits have zeners/surge
    arrestors etc. on them anyway, or would these not react quickly
    enough?
    Pip Luscher, Jun 3, 2005
  17. The Older Gentleman
    Salad Dodger Guest
    MiG 25 was the Foxbat.
    Flogger was the MiG 23.(and 27, oddly)
    | ___ Salad Dodger
    |_\_____/_| ..75409../..18748.../..3196./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR Landmarks: 18 Pts: 305 Miles: 1193
    Salad Dodger, Jun 3, 2005
  18. FFS, what do you think we're talking about?
    <fx: bashes head on keyboard>
    ..k`zxjfk.`zdfk.hj.k
    Do you ever read threads you post in?
  19. FFS, what do you think we're talking about?[/QUOTE]
    I quote this bit
    EMP as a weapon.
    No mention of any Nuke
    nope there mostly bollox anyway
    <--ROT13 it
    Spam Trap in Header
    GS850 Trike
  20. What exactly do you think an airburst is? I recall New Scientist
    publishing an article about (basically magnetohydrodynamic, IIRC) EMP
    devices based on conventional explosives, but for a long time now "airburst"
    has meant a nuke exploded at an altitude where there is little primary
    damage to the underlying countryside.
    Dr Ivan D. Reid, Jun 3, 2005
