Poltergeist strikes!
Discussion in 'UK Motorcycles' started by TMack, Jan 28, 2011.
  1. TMack
    TMack Guest
    In another thread a while back, I jokingly mentioned our household
    poltergiest. I described it as too weak to throw things or move things so
    it specialises in making things topple over. Well...the fucker got the
    V-strom this morning. I was starting out to work when I realised that I
    had left something in the house. I got off and put the bike on the
    sidestand on the driveway. I went back into the house and came out again
    a couple of minutes later. I then walked up to the bike, which was
    exactly as I had left it. Before touching it I turned back again to check
    that the front door was locked. As I turned my back and walked a
    couple of steps back down the drive I heard the crunch as the strom hit
    the ground. I looked round and it was just lying there - no kids running
    away or anything of that sort to explain it.
    Damage - one indicator one plastic handguard. I could understand it if it
    was on soft ground or hot-weather-melting tarmac but I could find no
    obvious reason why it had fallen. Probably down to it being a bit more
    upright than usual and a freak gust of wind but...(cue spooky music)it all
    seemed a bit odd.
    TMack, Jan 28, 2011
  2. TMack
    crn Guest
    Which way did it fall ?.
    One of my previous bikes ( a Jawa FWIW ) had a habit of rolling forward
    off of the sidestand at the least provocation. Something to do with
    the geometry of the sidestand not going far enough over centre.
    Cleaning out a load of crud and replacing the pivot bolt helped but
    some bikes seem to be prone to this.
    crn, Jan 28, 2011
  3. TMack
    TMack Guest
    Sideways
    TMack, Jan 29, 2011
  4. TMack
    Paul - xxx Guest
    Heheheh, you spoiled my vision of it endoing all on it's own .. ;)
    Paul - xxx, Jan 29, 2011
  5. TMack
    Vass Guest
    "TMack" wrote in message
    seemed a bit odd.
    www.weightwatchers.co.uk
    hth
    Vass, Jan 29, 2011
  6. TMack
    TMack Guest
    I may be generously proportioned but I do NOT create a gravitational field
    of sufficient strength to topple a bike!
    TMack, Jan 29, 2011
  7. TMack
    SIRPip Guest
    www.howtoformatusenetposts.com
    HTH.
    SIRPip, Jan 30, 2011
