Prace bets... NOW!
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Sep 17, 2010.
  1. Wicked Uncle Nigel
    JackH Guest
    I had a VFR (1) do this last year - parked up on a busy Saturday
    afternoon at Lakeside Shopping Centre.
    No breakdown cover and couldn't get hold of anyone with a van, so I
    went over to B&Q, bought a nice big lump hammer and pry bar, then
    smashed the lock barrel into submission to the point I could get the
    lock off.
    Despite it being really busy, no-one bothered to question what I was
    doing...
    (1) It was bought to be broken up anyway, so no real loss.
    JackH, Sep 17, 2010
  2. Wicked Uncle Nigel
    Gavin Guest
    A steering lock is just a metal tab that goes into a key (slot) in the
    headstock isnt it? How much effort is it to simply snap the tab off by
    heaving on the bars?
    Gavin.
    Moto Guzzi California Aquila Nera
    Suzuki GSXR600K1
    Twitter: http://twitter.com/gavin_wilby
    Blog: http://www.eekafreek.com
    Gavin, Sep 17, 2010
  3. Wicked Uncle Nigel
    JackH Guest
    Usually a solid cylindrical pin - on this, from memory, it must have
    been something like 8mm
    More than I could proffer - I did try this first before setting off
    for B&Q.
    JackH, Sep 17, 2010
  4. Wicked Uncle Nigel
    Gavin Guest
    Fair enough, Iv not looked closly at my current bikes, but I was just
    thinking of older ones I have had.
    An 8 mill cylinder isnt going to snap too easy I guess...
    Gavin.
    Suzuki GSXR600K1
    Gavin, Sep 17, 2010
  5. Wicked Uncle Nigel
    JackH Guest
    Once I'd stripped everything away and had a proper look at it, you
    could see the alloy around the hole in the frame the pin located in
    had come off a lot worse than the pin. ;-)
    JackH, Sep 17, 2010
  6. Wicked Uncle Nigel
    Ben Guest
    Should have typed 'jump'.
    Ben, Sep 17, 2010
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, Scraggy
    And it was.
  8. Wicked Uncle Nigel
    ian field Guest
    The CBX550 has a second click on the steering lock for parking lights.
    The 76 CB200 has a parking lights position on the IGN switch - but the
    steering lock is someplace else.
    ian field, Sep 18, 2010
  9. Wicked Uncle Nigel
    ian field Guest
    The old Honda ones advance a large brass stub into a hole drilled in the
    headstock centre tube, you won't shear the end off that without twisting the
    yolks.
    I'm told that if you smack the lock barrel hard enough with hammer and punch
    it shears a small pin on the side of the lock barrel and it pops out - the
    one time I tried this, it just mashed the pin along the side of the barrel
    and jammed it solid, leaving drilling out the only option.
    OTOH when I sold the 750 Commando and couldn't find the steering lock key to
    give the new owner, I just tapped out the steering lock assy with a
    screwdriver as a drift from under the top yolk - took less than 10s.
    Needless to say the new owner didn't bother to replace the steering lock -
    bought a decent padlock & chain instead.
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, ian field
    Well, you can't make an omelette without breaking a few eggs.
    Wicked Uncle Nigel, Sep 18, 2010
  11. Wicked Uncle Nigel
    SIRPip Guest
    That's two lots of egg on your face.
    SIRPip, Sep 18, 2010
  12. Wicked Uncle Nigel
    ian field Guest
    Rather egg on face than addled brains.
  13. Wicked Uncle Nigel
    I think you may have both.
    Oh, and you could learn to snip sigs?
    Ace, Sep 18, 2010
  14. Wicked Uncle Nigel
    ian field Guest
    Oh well, as long as you're having a go at me you're leaving someone else in
    peace.
    ian field, Sep 20, 2010
  15. Wicked Uncle Nigel
    As you seem to have been well and truly wooshed, Yolk != Yoke.
    Ace, Sep 20, 2010
  16. Wicked Uncle Nigel
    ian field Guest
    WOW - no shit!
