Problem with my suzuki tempter 1984
Discussion in 'Motorbike Technical Discussion' started by Nathalie, Jan 17, 2004.
  1. Nathalie
    Nathalie Guest
    Hi,
    I have
    The problems started when he began riding the last summer. I didn't
    idle very well, and after maybe five miles of riding, it would die and
    refuse to restart. I decided this sounded like gummed up crabulators,
    so
    we took the carb apart and gave everything a good cleaning. This
    helped somewhat, and it will idle and run just fine just after you
    start it up.
    Once it is slightly warmed up (enough to run with out the choke), the
    idle
    becomes very erratic. It will kind of slow down like it's going to
    stall,
    until you blip the throttle. Then it'll speed up again, and slowly
    fall
    until it's about to die. And still, after riding it for a few miles,
    it will die and refuse to restart.
    The stator have been changed the strarter was check and ajusted, after
    than i have a same problem. The first time the needle was changed,the
    carburate bowl was cleaned, the spearks plug chaned too...
    Thank for your help
  2. Nathalie
    Rev. Zack Guest
    sounds like you have an air leak in the intakes...when its running
    spray some wd40 around the intakes.
    Rev. Zack
    Rev. Zack, Jan 17, 2004
  3. <snip>
    Partially blocked pilot jet and/or incorrect pilot setting.
    The Older Gentleman, Jan 17, 2004
  4. check and make sure your petcock is flowing properly too
    Jason Templeton, Jan 18, 2004
  5. Nathalie
    Nathalie Guest
    Thank for you advise ;-)
    Nat
    Nathalie, Jan 22, 2004
