Project Idea - Trike ( I must be feckin' mad)
Discussion in 'UK Motorcycles' started by Donegal Paul, Nov 4, 2003.
  1. Donegal Paul
    Donegal Paul Guest
    OK, ive been toying with the idea of a trike for some time and realise that
    it will take a couple of years to complete anyway but there are several
    things i need to plan and be on the look out for.
    So, basic plan is probably mad, but its what i want.
    It'll have a Lambretta series 3 front end - will be able to source that easy
    enough.
    However, I want to put a large motorcycle engine into it, hence the need for
    it to be a trike realistically. People have put RD 350s and some guy even
    put a GT500 into a lambretta and thats fine.
    But I want more. Yep, Im looking to build a trike that has at least a 600cc
    motorbike engine in it.
    So, on the technical and engineering front my foremost concerns are, which
    engine and how do i drive the rear wheels? Both rear wheels will need to be
    independant on their axle i guess, ie freewheel independantly, but driving
    the wheels and the axle configuration will be dependant on the engine, in
    that it will depend on whether the engine i choose is belt, chain or shaft
    driven.
    Anyone got any recommendations for a trike?
    Ive been keeping an eye on ebay for engines, and there have been several,
    from 250s to a Goldwing 1000cc on there at the moment, though i think thats
    too excessive :)
  2. Donegal Paul
    Yoda Of Borg Guest
    easy
    I aint no expert but would aLambretta front end support the extra weight
    (especially under braking) let alone day to day use
    i guess you may get away with it if you had a rear engined trike, but mid or
    front engined?
    but worth getting an expert opinion..as i could be talking utter bollox (as
    usual)
    Yoda Out
    Reliant 850 Trike - Green
    Yoda Of Borg, Nov 4, 2003
  3. Donegal Paul
    Donegal Paul Guest
    "Yoda Of Borg" replied to DP
    I should have mentioned, it will definitely be a rear engined jobbie. Not
    sure exactly yet how im going to do it, but want to enclose the engine under
    the bodywork too, although obviously not the original stuff as it would
    never fit.
  4. Donegal Paul
    Yoda Of Borg Guest
    depending on budget, i thing you are pretty much restricted to car engines
    things like
    VW
    Mini
    Metro
    Skoda
    i dont think there would be many bike engines that you could use at the back
    with spending a bit of money, although i do remeber seeing a rewaco trike
    with a VTwin at the back (worth a google)
    Yoda out
    Trike 850 reliant - Green
  5. Donegal Paul
    Pete M Guest
    Yoda Of Borg made the world a better place for us by saying..
    a 1600 Ford crossflow (Mk2 Escort etc) is near as dammit bolts onto the
    Skoda gearbox.
    And you can get 180 bhp out of a well tweaked x-flow.. could be fun in a
    Lambrettrike!
    Pete M.
    Golf Gti (For Sale)
    Alfa Romeo 164 TS.
    Wahey, I'm a proper petrolhead again!"
    Liverpool, Great Britain.
    "you can lead a horse to water, but a pencil must be lead"
    Pete M, Nov 4, 2003
  6. Donegal Paul wrote
    You are fucking sick you are.
    repeat until you get better:-
    "There is no substitute for cubes."
    Now **** off until you _understand_,
    steve auvache, Nov 4, 2003
  7. Didn't know that. Interesting.
    GS 850 x2 / SE 6a
    SbS#6? DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Nov 4, 2003
  8. Wotcha.
    It need not take that long - I built one in around five weeks, with the plan
    of selling it.
    61 000 miles later, I'm still using it . . or would be if the gearbox hadn't
    spat its dummy ;-)
    http://www.moonshiners.freeserve.co.uk/gearbox.html
    Still - it keeps me off the streets for a while.
    No plan is ever mad where trikes are concerned.
    Hmm - might make the steering a tad "quick" - and I'd definitely look at
    upgrading the brakes.
    I remember seeing a 400 / 4 Honda engine in one once - a most interesting
    looking beast.
    Bike engines can be a damn sight more expensive than car engines - but I'd
    say the bike engine would be far easier to work with.
    Give this page a try - a bit long winded, but well worth it.
    http://www.btinternet.com/~jhpart/bktrikeo.htm
    Just take a nose at every trike you see and steal all the best ideas.
    Ebay is a most useful thing as far as trike building goes - I've got quite a
    few little odds
    and ends for mine from there.
    ^..^ Lone Wolf, Nov 4, 2003
  9. ^..^ Lone Wolf wrote
    Kin *lot* of reading and it is mostly words rather than pictures. Dunno
    about long winded or whatever yet as it takes a while over a 28k dialup.
  10. Donegal Paul
    Yoda Of Borg Guest
    Or what about mid-engined?
    http://www.subspace.pwp.blueyonder.co.uk/Trike_Page/Yodatrike.htm
    heres mine, built specifically for me and my disability?
    but as mentioned rob the best ideas and use them on a new build
    Yoda Out
    Trike Reliant 850 - Green
  11. Donegal Paul
    Donegal Paul Guest
    "Yoda Of Borg" said
    Was really hoping for a motorbike engine to be honest, mainly so i can
    contain it within bodywork.
    I found the V twin at http://www.rewaco-trikes.com/hs6.aspx
    I did consider using a VW or some such but think that might be too big on
    the rear end, also, i dont want to have an actual gearstick :-(
    unless theres a simplish way to convert it?
  12. Donegal Paul
    Donegal Paul Guest
    "steve auvache" said to Donegal Paul wrote
    The thing that put me off was that the GL1000 engine on ebay atm isnt a
    runner, otherwise i may have considered it :)
  13. Donegal Paul
    Donegal Paul Guest
    "^..^ Lone Wolf"replied to "Donegal Paul" who wrote
    Nice :)
    Planning to put a disc brake set up on the front thats for sure!
    Thats what im hoping , my numpty brain tells me i should get a nice quick
    big chain drive engine, manufacture my rear axle with an appropriate cog on
    and voila, trike!
    Already got it thanks to the links on fluffycats homepage about her trike
    Slowly making my way through it
    Cheers
  14. Donegal Paul
    Donegal Paul Guest
  15. Fun? Fucking lethal, more like.
    The Older Gentleman, Nov 4, 2003
  16. Sounds utterly brilliant.
  17. Donegal Paul
    mups Guest
    Shaft drive would be easiest I reckon to fit onto some cars rear diff and
    axle and if you're having an enclosed engine then probably a watercooled
    one as well. Hows about an old BMW K series motor. Shaft drive, good torque
    and a fairly low profile for a mid engine style fitment.
    Course I’ve never even thought about building a trike so this could be
    all bollox.
    mups, Nov 4, 2003
  18. mups wrote
    I just happen to know where there is a K100 rusting quietly away.
    Make a lovely trike it would.
  19. steve auvache wrote
    That was a kin hard read. Interesting though.
  20. Donegal Paul
    Donegal Paul Guest
    "steve auvache" replied to mups and "Donegal Paul"
    SNIP
    So, would I be better off with a shaft drive then as per the above
    suggestion and finding / molishing some form of interface twixt the two,
    rather than having a chain driven motor and molishing a "cog" onto a shaft
    to drive the rear wheels?
    I was avoiding the shaft drive on the basis that I didn't think it would be
    possible to join it to a car axle (notwithstanding the difficulties in
    finding an axle that will take quite low / small wheels anyway)
    Do you now? :)
    hmmmmmmmmmmm.
