Proximity sensors?
Discussion in 'Australian Motorcycles' started by CrazyCam, Jan 30, 2011.
  1. CrazyCam
    CrazyCam Guest
    Hi folks.
    I am thinking vaguely of getting some of those parking sensor thingies
    that flash cars seem to have as standard nowadays.
    My idea was to have a couple on the back of the bikes, and a couple on
    the front.
    The rear ones connected to a modulated pair of LED warning lights, to
    let following vehicles know they are too close, and the front ones
    connected to a single wee LED to warn me that I am too close to the
    vehicle in front.
    Any of you lot know what bits I need, and how they need to be wired up?
    I'd like this setup on all three bikes, but a 6 volt bit of kit for the
    baby Honda may be too much to ask.
    regards,
    CrazyCam
  2. CrazyCam
    Diogenes Guest
    I think Zener diodes should work for cutting 12v back to 6v, so I
    think it's a go. Other here will give you more reliable tech info no
    doubt.
    You can get zener diodes from Jaycar.
    http://en.wikipedia.org/wiki/Zener_diode
    Onya bike
    Gerry
    Diogenes, Jan 30, 2011
  3. CrazyCam
    Nev.. Guest
    Has this been done before or was it an original idea? I thought those
    parking sensors on cars had quite a limited range, like 1 metre or less.
    Another thought.. if you have something on the back of the bike which
    gives some sort of active response to the actions of following vehicle,
    isn't there a possibility that that is going to actually encourage
    tailgating? In the same way that poking a cat with a stick might get
    you scratched, but the funny lolcatz video you can record and put on
    YouTube makes the potential scratching worth the reward. Ie the reward
    of making lights on your bike flash might be more appealing than leaving
    a safe distance.
    "Hey Thommo, look at the bike. I can make it's lights go on..."
    *accellerate*brake*accelerate*brake*accelerate*brake*
    "Pass me another tinny mate."
    Nev..
    Nev.., Jan 30, 2011
  4. About 2 metres Nev
    Also Cam,
    What's wrong with your eyes ??
    Can't you tell if someone is too close?
    If someone closes up on me too much, then I give it a bit and move away
    George W Frost, Jan 30, 2011
  5. CrazyCam
    Nigel Allen Guest
    <insert enormous grin here>
    I can just see this now. Worst part is I think I know this "Thommo" guy
    - and a hundred like him.
    How about one of those programmable scrollers on the back of the bike
    with a suitably polite message.
    Or better yet, rig the bastard up to your brake lights. Or a rear facing
    Xenon spotty. Or both!
    Muhahahahahahahah
    N/
    Nigel Allen, Jan 30, 2011
  6. CrazyCam
    CrazyCam Guest
    On 01/30/11 3:09 PM, George W Frost wrote:
    Well, <cough> it's like this..... I had thought, it seems, wrongly, that
    parking sensors used infrared light, much like err, hairdryers. ;-)
    regards,
    CrazyCam
  7. You use a hair dryer for parking ??
    George W Frost, Jan 31, 2011
  8. CrazyCam
    Peter Guest
    No.
    I think he was meaning hand dryers.
    (unless it is a height thing)
    Peter, Jan 31, 2011
  9. Is Cam so short that he can't reach the hand dryer and has to use a hair
    dryer?
  10. CrazyCam
    Deevo Guest
    How about wiring them up to an exhaust mounted flamethrower instead?
    I never felt that visibility was that much of an issue on any of my bikes.
    Seems a bit silly IMO.
    Deevo, Jan 31, 2011
  11. CrazyCam
    atec77 Guest
    I remember once at the bandcamp airport there were no towels and I had
    to dry ,....
    atec77, Jan 31, 2011
  12. Saw a really neat bike which could do that a year or so ago in Melbourne
    It had a helicopter jet engine in it and whoever was behind it when he took
    would get a singed face and whatever else.
    It wwas odd to hear the whine of the jet motor build up before he let the
    brakes off
    Then with a whoosh, he was gone up and over the hill
  13. From the sounds of it, he needs it the other way around - getting a 6-volt
    bike to power a 12-volt accessory. In that case, he'll need a voltage
    inverter, which can either be relatively cheap (if the accessory draws very
    little current), or painfully expensive.
    Given the potential complexities, I'd be more tempted to simply strap a
    separate 12-volt battery to the bike and power the transducers from that.
    However, the proper solution lays here;
    http://www.aaroncake.net/circuits/6-12conv.asp
    Bob Milutinovic, Feb 2, 2011
  14. CrazyCam
    Lars Chance Guest
    Lars Chance, Feb 2, 2011
  15. CrazyCam
    Diogenes Guest
    You're bloody right of course. Again, I've got things arse-about.
    Maybe I need re-wiring?
    Onya bike
    Gerry
    Diogenes, Feb 2, 2011
