Q. Headlight and MOT.
Discussion in 'UK Motorcycles' started by Eiron, Sep 16, 2007.
  1. Eiron
    Eiron Guest
    You can call me a TC but I've only just noticed, after owning my SOB for
    nine months, that the headlight dips to the wrong side.
    Is taping over the triangular bit on the glass OK for the MOT test?
    Eiron, Sep 16, 2007
  2. Eiron
    Pete Fisher Guest
    Failing demon cunning trickery of the Gilera kind (involving twisting
    the bulb round in its holder) that should suffice for an MoT. Not good
    enough for an MSVA though.
    | Pete Fisher at Home: |
    Pete Fisher, Sep 16, 2007
  3. Eiron
    The headlight on the Ural is the wrong way round. To compensate, it has
    been rotated in its mount. This was noted on the last MOT, but only in
    passing: the tester wasn't bothered about it.
    The headlight on the Dnepr was also the wrong way round. This was taped,
    and had no problems on MOT. Interestingly, it was taped with "invisible"
    sellotape, which did the job without being too obvious.
    platypus, Sep 16, 2007
  4. Eiron
    Eiron Guest
    Difficult to rotate a rectangular headlight. Tape will do for the MOT
    tomorrow then I'll try the scrappies for another lamp.
    Eiron, Sep 16, 2007
