Qld to get LAMs!
Discussion in 'Australian Motorcycles' started by Knobdoodle, Nov 13, 2008.
  1. Knobdoodle
  2. Knobdoodle
    33-45 Guest
    Quote:
    The Government will also introduce a Learner Approved Motorcycle Scheme
    to replace the existing 250ml engine capacity restriction for class RE
    motorcycle licence holders with a restriction based on a 150kW
    power-to-weight ratio and a 660ml upper engine capacity limit.
    Can someone please explain what this means...for the not so tech minded?
    I recently got my RE licence..will this mean I can ride a 660cc
    bike...the requirement being it's under the 150kw limit?
    Does such a bike even exist?
    Sean
    33-45, Nov 13, 2008
  3. Knobdoodle
    theo Guest
    How is the 660 version different to the full-blown one?
    Vicroads says
    From 1 July 2008 there will be new regulations for Learner and
    Probationary motorcyclists in Victoria with the introduction of a new
    Learner Approved Motorcycle Scheme (LAMS).
    An approved LAMS list of motorcycles and scooters, which will be
    updated as new models are approved by VicRoads, provide details of all
    motorcycles and scooters that learners and newly licensed riders are
    permitted to ride. View the approved list of motorcycles for novice
    riders.
    The LAMS list includes moderately powered motorcycles with an engine
    capacity up to and including 660cc which do not exceed a power-to-
    weight ratio of 150 kilowatts per tonne.
    LAMS gives novice riders access to a greater range of motorcycles and
    scooters that are appropriate to their level of experience and more
    suitable to riders of all sizes.
    The introduction of the LAMS in Victoria will contribute to a more
    consistent approach to vehicle restrictions for learner and newly
    licensed riders across the country as similar schemes operate in South
    Australia, Tasmania, New South Wales and the ACT.
    Nsw says
    Approved motorcycles for novice riders
    Revised 23/10/2008
    As from 6 September 2002 a Learner Approved Motorcycle (LAM) scheme
    for novice riders (both learner and provisional) will commence on a
    trial basis. The LAM scheme will allow novice riders to ride
    moderately powered motorcycles with an engine capacity up to and
    including 660ml and which do not exceed a power to weight ratio of 150
    kilowatts per tonne and are shown on this list. The following list,
    which will be adjusted as new models are approved by the RTA, displays
    details of all motorcycles that can be ridden by learner and
    provisional riders.
    Theo
    theo, Nov 13, 2008
  4. Knobdoodle
    theo Guest
    A great many, even most, motorcycles under 660 fall within this list,
    see
    http://www.rta.nsw.gov.au/licensing/tests/motorcycleridertrainingscheme/motorcyclesnoviceriders.html
    Includes the SV650 and the Moto Guzzi V65, but not an R6.
    Theo
    theo, Nov 13, 2008
  5. Knobdoodle
    33-45 Guest
    Ok, I think I've done this right..
    How is power to weight ratio calculated?
    • The power output (kilowatts) is divided by the tare weight of the
    motorcycle + 90kg (for rider and fuel).
    The result is then multiplied by 1000 (to convert to kW per tonne), i.e.
    Engine power (kW)
    Tare weight (ie mass of motorcycle in kg) + 90kg (80kg rider weight +
    10kg for
    fuel)
    x 1000
    Spada
    *Power:*40.00 HP <http://www.bikez.com/jargon/index.php#horsepower>
    (29.2 kW <http://www.bikez.com/jargon/index.php#kilowatt>)) @ 12000 RPM
    <http://www.bikez.com/jargon/index.php#Revolutions>
    *Dry weight:*140.0 kg (308.6 pounds)
    So: 29.2 divided by 230kg x1000 =126.9 PWR
    Note to self...lose 35kg...
    29.2 / 195kg x1000 = 149.7 PWR
    Still legal and I can audition for a melbourne cup ride...lol
    33-45, Nov 13, 2008
  6. Knobdoodle
    John Dwyer Guest
    see
    Theo
    I have checked the RTA website and they mention a Suzuki SV650SU (whatever
    that is). My understanding is that the current SV650 puts out about 52kW
    and weighs about 175kg dry. You will need a rather heavy rider to obtain a
    power to weight ratio of less than 150kW per tonne. If you allow 20kg for
    fuel and other fluids, allow even 100 kg for a rider in riding gear, you
    will obtain a power to weight ratio of 170 to 175 kw per tonne. While I am
    open to arguments, I doubt that the current SV650 is learner legal, despite
    what is stated on the NSW RTA website.
    John Dwyer.
    John Dwyer, Nov 13, 2008
  7. Zebee Johnstone, Nov 13, 2008
  8. Knobdoodle
    knobdoodle Guest
    I believe the ACT just has the 150kw/tonne without the 660cc
    restriction (so the learner-you could theoretically ride a big 'Guzzi
    or Harley)
    knobdoodle, Nov 14, 2008
  9. In aus.motorcycles on Fri, 14 Nov 2008 10:41:01 +1100
    It is a restricted version.
    THe SV650SU is. The SV650 isn't. Seems simple enough to me.
    Zebee
    Zebee Johnstone, Nov 14, 2008
  10. Knobdoodle
    theo Guest
    OK, I didn't know that. Are there any states apart from WA who don't
    now have LAMS?
    Theo
    theo, Nov 14, 2008
  11. OK, I didn't know that. Are there any states apart from WA who don't
    now have LAMS?
    Theo
    George W Frost, Nov 14, 2008
  12. No. NT is (technically) not a state.
    Andrew McKenna, Nov 14, 2008
  13. Knobdoodle
    JL Guest
    Errr no it doesn't yet include the SV650. It will shortly when the
    restricted SV hits our shores
    JL
    JL, Nov 14, 2008
  14. Knobdoodle
    JL Guest
    The SV650SU is a restricted version of the SV, and the power to weight
    is calculated used a nominal weight rider of I think it was 75Kg. Your
    actual weight is not relevant for the purposes of approving which bike
    you can ride. The list is pre-approved based on weights and power
    recorded during the homologation process
    JL
    JL, Nov 14, 2008
  15. Knobdoodle
    JL Guest
    Nope
    JL
    (not according to amcn anyway)
    JL, Nov 14, 2008
  16. Knobdoodle
    JL Guest
    yeah ACT is the only one for the pure power to weight no capacity
    limit
    JL
    (660 is a bit of an odd threshold in my opinion)
    JL, Nov 14, 2008
  17. Knobdoodle
    ChrisR1 Guest
    limit
    JL
    I was doing Rider Training on weekends for RTA contracted providers when
    LAMS came in John. From memory the 660cc limit was picked as there were a
    couple of 660cc singles (Yamaha SZR660 being one I think) that manufacturers
    argued for inclusion in the scheme.
    Hence 660cc.
    Chris
    ChrisR1, Nov 14, 2008
  18. Knobdoodle
    jl Guest
    Mmm yes, I gathered it was intended to pickup the SZR660 for example, as
    opposed to a 650 cutoff, but wasn't my point. I thought 660 was an odd
    point not because it wasn't a round number but because it seemed a bit
    low considering the ACT had had their open power to weight limit in for
    a little while at that stage and it seemed to be successful. I can only
    assume they thought there was some good reason to cut out the Massey
    Davidsons and etc that were ok under the ACT legislation
    JL
    jl, Nov 14, 2008
  19. Knobdoodle
    CrazyCam Guest
    The story I heard at the time of NSW discussing LAMS was that they
    worked out an unlimited capacity would allow learners to ride ST1100's
    which they seemed to think was a bad thing.
    regards,
    CrazyCam
    CrazyCam, Nov 14, 2008
  20. Knobdoodle
    Nev.. Guest
    Is it really an odd number, or is it just carrying on the tradition of
    the 250cc limit (which was actually written up in the legislation as a
    260cc limit to allow for the slight variations and avoid the ridiculous
    anomaly where a 248cc bike would be learner legal but a 251cc bike would
    not). Surely this is a case of them choosing 650cc because it is a
    popular number with manufacturers, and then adding 10cc to allow for
    slight variations in the actual capacity.
    Nev..
    '07 XB12X
    Nev.., Nov 15, 2008
