Queston: honda Motorcycles, engines free running or not.
Discussion in 'Motorcycle Technical Discussion' started by Jelly, Nov 12, 2003.
  1. Jelly
    Jelly Guest
    aside from the obvious , when chains snap or derail and jam, and anything can
    happen.
    are most honda's non -interference engines?. Pistion > Valves.
    I have CB750k6 SOHC4 and CB750 NH- 1993 DOHC4 and nx250.
    i was just curious.
    thanks for any help or direction, did massive search on line to no avail.
    Jelly the aby normal.
    Jelly, Nov 12, 2003
  2. Jelly
    JS9 Guest
    when chains snap or derail and jam....
    I'd say no, the valves will kiss the pistons. Counter opinions welcome.
    JS9, Nov 12, 2003
  3. Jelly
    Steve H Guest
    Surely with the compression ratio's bikes run at and the comparatively
    larger valves than cars, it would be pretty rare to find any bike that is
    non-interference? Certainly with my Land Rover Discovery TDi it has a
    camshaft thats belt driven with pushrods to the rocker arms. If the belt
    snaps, pistons & valves will meet but the worst damage is usually a bent
    pushrod or two and maybe some broken rockers OTOH most OHC cars these days
    bend valves and snap cams if the drive belt/chain fails and I'd expect the
    same with any OHC or DOHC bike engine.
    Steve H
    Steve H, Nov 12, 2003
