R6 - no lo-beam
Discussion in 'Australian Motorcycles' started by qwerty, Aug 22, 2007.
  1. qwerty
    qwerty Guest
    Hi guys,
    I've got a 2001 R6. Yesterday the lo-beam headlights stopped working.
    Hi-beam works fine. There is one globe on either side - both globes are
    fine. I can't see anything in the fuses which might cause this - the
    headlight fuse is ok.
    Why is this happening? Is it the switch?
    cheers
    Steve
  2. This is a general comment (I've no idea about your particular bike), but IMO
    it's most likely the switch.
    Many years ago I had a Nissan Nomad van, and it developed a similar fault
    with an additional twist - I had no low beam, and with the headlights
    switched on I also had no left indicators.
    I sourced a wiring diagram from a friend who worked at a Nissan dealership
    at the time, and sure enough the line powering the low beam relay was also
    the one running to the left-hand indicators. Took the switch apart, gave the
    contacts a clean, and everything came good.
    Assuming you haven't dropped the bike (not likely to drop it onto the switch
    & still be able to write about it here), I'd say it's most likely to be dirt
    build-up on the contact(s) rather than anything broken internally. I just
    hope for your sake it's relatively easy to (1) get to the switch and (2)
    disassemble/clean/reassemble it.
    Bob Milutinovic
    Cognicom - "Australia's Web Presence Specialists"
    http://www.cognicom.net.au/
    telephone (0417) 45-77-66
    facsimile (02) 9824-2240
    Bob Milutinovic, Aug 22, 2007
  3. qwerty
    (snip)
    This is common with people who fit higher than 55W bulbs to their
    headlights.
    A 120W bulb is running 10 amps through those skinny wires and small contacts
    in your switch and that's gonna' cause a lot of heat if there's any
    resistance!
    Knobdoodle, Aug 23, 2007
  4. Ok - thanks guys, you pretty much confirm my thoughts.
    I suspected the switch assembly might be a surprise waiting to happen -
    thanks for the warning.
    Bike hasn't been dropped - well, not recently anyway :-\
    Haven't noticed any flickering of lites indicating imminent problems.
    the annoying thing is I walked outta work yesterday to a flat - oh joy - so
    i went to a shop in the city where they very kindly got me a tyre & fitted
    it straight away. Good on ya Yamaha City service centre here in Melbourne -
    very obliging. The problem **seemed** to happen right after that (but it
    coulda be earlier in the day - I can't see the connection btwn rear tyre &
    lites anyway...). So I had it in the shop but didn't notice the problem (it
    was daylight). It's always the way.
    steve
    Bernard Omigoo, Aug 23, 2007
  5. qwerty
    Theo Bekkers Guest
    Many older small bikes, especially road/trail, with direct AC lighting ran
    35/35 for the headlight.
    Theo
    Now waiting for somebody to say "AC lighting?"
    Theo Bekkers, Aug 24, 2007
  6. qwerty
    Yeebok Guest
    Good call, GB !
    It always takes just one person to spot the obvious problem.
    Yeebok, Aug 24, 2007
  7. qwerty
    Someone told me about the Yamaha 35W low-beam H4 bulbs (from a TDM I think)
    and I thought that'd be the answer to the starting problems I was having
    with my headlights-always-on Triumph Sprint so I went to Repco but it took
    me yonks to convince the bloke they might exist and then I had to justify
    why I wanted them before he finally looked in the Hella catalogue and told
    me "nope".
    Grrr.
    Knobdoodle, Aug 24, 2007
  8. qwerty
    boyds Guest
    Steve
    I've had bulbs that looked just fine, but when you put a meter across
    them the show open circuit.
    Check the bulb thoroughly before you rip the switch apart!
    SteveB
    boyds, Aug 24, 2007
  9. qwerty
    OK; after doing some Googling it seems like the lower-wattage Halogen is a
    HS1 bulb. They range from 35/35W to 60/60W.
    It was launched as the new standard headlight bulb for motorcycles but it
    seems it didn't really take off.
    The base is designated PX43T and differs slightly from the standard H4 which
    is a P43T.
    <http://www.lighting.philips.com/ass...sumer_lighting/car_lighting/s_prod_h4_ed.jpg>
    <http://www.lighting.philips.com/ass...umer_lighting/car_lighting/s_prod_hs1_ed.jpg>
    The piccies here seem to show that both have GB's two-little-tabs but the
    HS1 (35W) bulb has a fatter middle (top) locating tab (and no dent) so it
    actually looks like the H4 high-wattage bulb would fit into a HS1 receptacle
    but not the other way around?!!?
    Knobdoodle, Aug 25, 2007
  10. qwerty
    You're right; I stared at those two photos but missed the fact that the tabs
    are further apart on the HS1.
    I see there's dents inside all three locating tabs on the H4 too; not just
    on the centre one.
    I betcha' the combination of those slight differences has caused some major
    swearing from bamboozled bikies over the years......
  11. Probably crushed the wire when they put the bike on the hoist to change
    the tyre.
    Doctor Shifty, Aug 25, 2007
  12. Ah, yes, that's the Jesus spring. True believers already know about this.
