I should fix mine. I popped a spanner across the poles of the thermistor which screws directly into the back of the radiator and with a 'pop' the fan set off happily. So, it isn't the electricals. I can think of two options, thermistor is buggered and to test this I need to let all the sugary blue liquids out into a bucket, remove and then boil the thermistor in hot water to see if the resistance across it drops, correct? The other option is that the pump is knackered and not pushing water from the block into the radiator. I'm pretty sure that there's fluid in there because the bike's not blown up and the header tank has fluid between the expected marker lines. Were it a pump, how can I check if it's working or not?
