rain grooves- consensus?
Discussion in 'Bay Area Bikers' started by Mike Jacoubowsky, Aug 24, 2004.
  1. So just how dangerous are rain grooves? They were certainly disconcerting
    when I was descending the Grapevine on I5 last night, but are they actually
    dangerous? Is there evidence that they have actually caused accidents?
    Intuitively, anything that causes you to be nervous would seem to be a bad
    thing, but I just don't recall reading an accident report where someone
    suggested that rain grooves were the cause.
    Also, noticed that the one lane of I5 southbound, somewhere between the
    Grapevine and Los Banos, had about a 6-inch-wide wavy mild depression that
    went on for quite a few miles. Since it was dark I could see it but
    couldn't tell what caused it, but it did cause some wobbling of my front
    end.
    By the way, rain grooves aren't any fun on road bicycles either.
    --Mike-- Chain Reaction Bicycles
    www.ChainReactionBicycles.com
  2. Mike Jacoubowsky
    Ryder Rick Guest
    Rain grooves are not a "problem" unless your tires are squared off, or you
    have too tight a grip on the bars. Try it one-handed next time.
    Make sure your tires are aired up and not worn flat in the middle. Check
    head bearing adjustment and swing arm bearing preload.
    RickB
    Ryder Rick, Aug 24, 2004
  3. I can't recall seeing those grooves on anything other than freeways.
    Check out Highway 92 between Skyline and Crystal Springs Reservoir.
  4. it varies with the tires.. When I tried Dunlop D205's, my bike would
    wander all OVER on grooves, while Metz MeZ4's and Z6's just laugh them
    off.
    John R Pierce, Aug 24, 2004
  5. Graham Hill Rd just above Roaring Camp
  6. Mike Jacoubowsky
    notbob Guest
    I've never considered rain grooves anything more than a political pork
    barrel, myself. I drove CA highways, sometimes for a living, for 30 years
    before their appearance and only once in all that time did I see a vehicle
    skid out on rainy pavement. I think the whole thing is a scam. But, I'd be
    open to argument on their need/efficacy, information which seems to be
    suspiciously scarce. There's no doubt in my mind they accelerate the
    overall degredation of our roadways.
    nb
    notbob, Aug 24, 2004
  7. Mike Jacoubowsky
    Ryder Rick Guest
    In Washington State you can drive for miles without touching your steering
    wheel as your car will follow the twin troughs worn into the pavement by
    studded tires. Can you imagine what Calif freeways would look like if we
    used studded tires? <shudder>
    RickB
  8. Rain grove wiggles generate fear in the inexperienced rider... fear
    smells and it loves all your attention to the degree of failing...
    Larry L
    94 RC45 #2
    Have a wheelie NICE day...
    Lean & Mean it in every corner of your life...
    If it wasn't for us the fast lane would rust...
    V4'S are music to the seat of my pants...
    1952 De Havilland Chipmunk...
    Yank and bank your brains loose...
    http://members.ebay.com/aboutme/-xlax-/
    http://home.comcast.net/~netters2/
    http://www.fox302.com/index.pl?s=vg&user=netters2
    Larry xlax Lovisone, Aug 24, 2004
  9. They're fine if your tires are decent. Otherwise.. umm.
    Now, on the VF500 of yours, do you still have the ol 16" front wheel?
    I recall that finding decent rubber for that was challenging..
    cds
    PS - A 17"er from an F2 fits without too much heartache, btw
    C. Deforrest Smith, Aug 24, 2004
  10. Mike Jacoubowsky
    cstatman Guest
    they are really really hard on smaller bikes, (250cc, etc) or older bikes
    with skinny tires (305 Superhawk)
    and old bikes with skinny ribbed tires (royal enfield bullet-350) makes
    rain grooves on hwy 280 absolutely terrifying at speed.
    Assuring you of my best intentions at all times,
    Charles Statman
    Rocket Scientist/Wonderboy/Women's Legs Shaven
    DoD the Un-Numbered One
    cstatman, Aug 25, 2004
  11. Mike Jacoubowsky
    Alan Moore Guest
    On a bicycle, thanks to narrow tires, they're worse than on a
    motorcycle. On your motorcycle, just stay light on the bars, and
    pretty soon you'll hardly even notice them. I rode I-5 from Los Banos
    into LA just a few weeks ago, and can't recall them at all.
    Al Moore
    DoD 734
    Alan Moore, Aug 25, 2004
  12. Mike Jacoubowsky
    Bill Bornman Guest
    actually they're the solution to pavement with a low coefficient of friction.
    the cost is negligible for concrete pavement - they're created as the paving machine finishes the
    surface. For asphalt pavement they're more expensive, but cheaper than people getting injured/killed
    due to an unsafe roadway.
    you must not have been paying attention. Weather conditions are tracked for accidents on state
    highways. A higher prevalence of wet weather accidents will prompt an investigation and corrective
    action if required.
    pavement is grooved to increase the coefficient of friction of the concrete surface (similar to a
    broom finish on a sidewalk). Only very rarely are they cut into existing asphalt pavement - mostly
    where there is a demonstrated traction problem. Here in California the freeway surface is often
    tested for skid resistance* prior to opening to traffic. There's rarely a problem with new pavement
    not meeting the friction requirements. On the other hand I've seen cases (EB80 in Albany, WB80 in
    Crockett) where the pavement has been too rough (thus making it too loud for people living nearby)
    and was ground smooth.
    There's significant doubt in my mind that the surface texture has any more than negligible impact on
    pavement life. If you look at older pavement surfaces they are noticeably smoother than new
    pavement, from "erosion" of the surface layer. This has no impact on ride quality. Most "potholes"
    form from the pavement breaking apart into pieces not from the surface wearing away.
    *you can check out the test method at:
    http://www.dot.ca.gov/hq/esc/ctms/CT_342.pdf
    Bill Bornman, Aug 25, 2004
  13. Mike Jacoubowsky
    Ray Curry Guest
    The original justification was some people ran bald tires. An airport
    study on rain grooves showed some reduction in hydroplaning. Ergo,
    Caltrans (even dumber than the people with bald tires), decides to put
    them on the highway. Now since this is the same group of public
    dis-servents that put's sand down on fresh asphault, one might be
    tempted to think they don't mind causing a bit of upset for bikers but
    I've been told no, it's only for the benefit of the bald tire people.
    Problem is that the airport study tested groove that were 90deg to the
    direction of the road allowing the water to go sideway where as to be
    cost effective on the highway, the groves are in the direction of
    travel. Also airplane tires are of a very special broad rib design with
    no cross hatch. I have seen a tire test in one of the car magazines that
    shows rain groves extend braking distance on all but bald bias ply tires
    in both wet and dry tests and has almost no effect on the resistance to
    aquaplaning because the water tends to build up in front of the tire.
    Worse yet, after that study which Caltrans had to admit to, they
    continued groving the roads for several years. Brand new roads...:(.
    I recall one case, many years ago, an LA CHP on an early Z1 police bike,
    narrow front ribbed tires and high mounted in the rear heavy radio went
    down because of the rain grooves. The problem is a lot less likely now
    with block tread tires and much better suspensions and tighter frames.
    Now the steel grate bridges in Seattle, those will move you around a
    couple of feet, even in my politically incorrect SUV.
    Ray Curry, Aug 25, 2004
  14. You ride your road bike bicycle on freeways?
    I should have previously mentioned that something like 20% of the freeways
    in California *are* legal to ride a bicycle on. Anyplace where there's no
    nearby alternative, it's legal... which means there are many, many miles of
    I5 and a good number on I80 (heading up towards Tahoe) where you can legally
    ride a bicycle.
    Would you want to? Not if you can possibly avoid it! In most areas it's
    reasonably safe to do so (pretty good visibility) but it's *incredibly*
    boring. If you think 244 miles of I5 don't go by fast enough on a
    motorcycle with the throttle open wider that it ought to be, just think what
    it's like on a bicycle.
    Mike Jacoubowsky, Aug 25, 2004
  15. Mike Jacoubowsky
    Michael Guest
    <involuntary shudder>
    -- Michael
    Michael, Aug 25, 2004
  16. Mike Jacoubowsky
    notbob Guest
    You and Ray just confirmed my suspicions.
    The other great pork barrel/scam is the the miles of sound walls that make
    ba driving a flashback to Dawn of the Dead. Miles of beautiful sound
    absorbing flora and fauna uprooted to enclose us in a sterile concrete
    causeway. While some of it was justified, at $1M per mile, most of it is
    outright political scumbaggery.
    nb.
    notbob, Aug 26, 2004
