Rattle guns
Discussion in 'UK Motorcycles' started by Gavin, Aug 30, 2010.
  1. Gavin
    Gavin Guest
    Probably a stupid question but, do you have to use impact sockets in a
    rattle gun, or can you also use normal sockets?
    Bought one today at 80% off from a one sale sale at a garage, but I
    only have standard 1/2" sockets not any impact ones.
    Gavin.
    Moto Guzzi California Aquila Nera
    Suzuki GSXR600K1
    Twitter: http://twitter.com/gavin_wilby
    Blog: http://www.eekafreek.com
    Gavin, Aug 30, 2010
  2. Gavin
    Just shut your eyes when you're using them.
    If you've got impact sockets then use them but if you don't have them
    don't lose any sleep over it. I'd avoid the really cheap sockets that
    split if you use a breaker bar with them but otherwise I'd not worry.
    If you're really paranoid then you can wrap the socket in gaffer
    tape, it won't make it any stronger but at least you won't be worried
    by the chrome flaking off.
    Andy Bonwick, Aug 30, 2010
  3. Gavin
    You can use normal ones, but I'd stick to 6 sided on anything remotely
    tight.
    Krusty, Aug 30, 2010
  4. Gavin
    greybeard Guest
    Yep.
    Your are supposed to use impact ones, normally a powder black finish.
    I have one or two but use ordinary sockets as well.
    Standard socket "apparently" can shatter when used with a rattle gun so take
    care!
    greybeard, Aug 30, 2010
  5. Gavin
    crn Guest
    It depends.
    If the rattle gun is good and the nut is tight it will shatter a
    standard socket and the flying bits could HURT, especially in the eye.
    DAMHIKT
    Get the proper sockets.
    crn, Aug 30, 2010
  6. Yes the gun will rip standard sockets apart
    steve robinson, Aug 30, 2010
  7. Gavin
    What makes you say that?
  8. Gavin
    Experience of using cheap sockets?
    FWIW I've used decent non-impact grade sockets with impact tools
    plenty of times and I'll do so again.
  9. Experience , you may get away with the smaller sizes ( ive done it
    myself ) but once you start getting up around the 20mm plus sizes
    standard sockets split apart on any very tight or seized nuts or just
    chew the nut up , conversly they jamb on the nut or bolt heads if
    your tightening them
    Most rattle guns will happily apply torques in exess of 300 foot
    pounds and the cheaper units are not that controllable .
  10. Gavin
    Same here, hence my question.
  11. Gavin
    So say that then, rather than 'the gun will rip standard sockets
    apart', which simply isn't true.
    I've got a couple of sets of impact sockets, but I still use my 25 year
    old Kamasa sockets occasionally without problem.
  12. Ok i see your point
    Older socket sets do seem to be far more robust , ive got sets of
    kamasa and teng both around 25 years old good kit
  13. Gavin
    Kamasa rock. Think I paid 15 quid for my huge set, including some long
    6-point jobbies. None of the sockets have broken & even the ratchets
    still work.
  14. Gavin
    Adrian Guest
    I mentioned on the classic group earlier about using a 32mm socket on my
    rattler to batter some over-enthusiastic peening into submission.
    That was a 32mm bi-hex non-impact.
    Adrian, Aug 30, 2010
  15. Gavin
    I had one like that - most are MIA but what remains still works. I have
    some old Britool and Schmole sockets that are worn out but not broken.
    IYSWIM.
    sweller, Aug 30, 2010
  16. Gavin
    Simon Wilson Guest
    +1, except I did manage to split (not shatter) one of my Kamasas using a
    rattle gun. Found a replacement for it cheap on ebay.
    Simon Wilson, Aug 30, 2010
  17. Gavin
    Gavin Guest
    Having just looked I have a single impact socket, the one that gets the
    rear spindle off the GSXR - looking at the comments, and the concencous
    being that standard sockets *might* shear/ snap/ shatter, Ill simply
    buy in impact sockets as and when I need them.
    Gavin.
    Suzuki GSXR600K1
    Gavin, Aug 30, 2010
  18. Gavin
    Beav Guest
    You can use any socket you like, but the "normal" ones are likely to split a
    lot sooner and possibly even shatter, but Machine Mart do a set of impact
    sockets for pennies, so there's no excuse for using non impact sockets.
    Also a lot depends on how hard the rattler smacks the sockets.
    Beav, Aug 30, 2010
  19. Gavin
    Beav Guest
    Standing behind the gun usually results in exploding sockets being nowhere
    near the eyes.
    Safety nazi.
    Beav, Aug 30, 2010
  20. Gavin
    Beav Guest
    I do it all the time and the only time I've ever split a socket, it was a
    shitty Britool copy from China.
    Beav, Aug 30, 2010
