RD350 no spark/flooded
Discussion in 'Motorcycle Technical Discussion' started by monk, Aug 21, 2005.
  1. monk
    monk Guest
    Hi all, bought another bike this weekend (not even finished the KE125
    I bought last month) I may be addicted! Anyways, This is a 74 Yam
    RD350 been sitting for a couple of years but everythings in good
    condition (relatively speaking of course) the battery is new, I've
    cleaned out the carbs compression is good, lights turn on etc. but
    I''ve got no spark and Ive flooded the engine I think.
    I've got power at the points, and resistance looks ok in the
    primary/secondary and plug wires/caps. Do I need to replace the plugs
    since I flooded them?
    Also, I read somewhere that I will need to clear all the gas out of
    the engine by putting a rag over the plug holes and kicking it over
    until i get it all out, since I have oil injection will it be filling
    everything with oil?
    Thanks
    monk, Aug 21, 2005
  2. monk
    Nemo Guest
    It's hopelessly screwed up. You should sell it to me cheap. <G>
    Ed Cregger
    Nemo, Aug 21, 2005
  3. monk
    Leon Guest
    I had one of those new in 1974. The plugs could be a bit troublesome,
    if they had the wrong heat range or the bike was driven too slowly they
    used to oil and had to be replaced. Also, the ignition timing is
    critical - I used to set it once a week.
    Best to take the plugs out, kick the engine over several times to get
    rid of all the fuel in the crankcase, and check that you have a decent
    spark. You needn't worry about the oil, it depends on the engine speed.
    Watch the front brake, the piston could seize on one side which makes
    the wheel liable to lock, especially in the wet. It happened to mine.
    Leon
    Leon, Aug 21, 2005
  4. Considering that the engine has being sitting without being started for
    two years, it wouldn't hurt to replace the plugs and might even help
    quite a bit.
    It seems that in that era, motorcycle ignition systems didn't supply
    very much voltage, I'm talking about only 9,000 to 12,000 volts here,
    and the voltage rise time was critical. The voltage could leak away
    across the oil fouled insulator faster than it could build up to make a
    spark.
    And, since the engine has sat for a while, it's just possible that
    condensation has gotten up inside the park plugs. I've had plugs that
    just mysteriously would fire unless I heated them up in a gas flame.
    That points toward evaporating water from inside the plug.
    With so little ignition voltage, the spark can't jump a gap that's more
    than about 0.025 to 0.028 inches, the center electrode needs to be kept
    filed flat so it has sharp edges that the spark can easily jump from.
    And the small plug gap makes it harder for the fuel air mixture to find
    the gap. In engines with more voltage, we were able to widen the gap
    out to 0.032 to 0.035. But we were using automotive ignition coils we
    bought at K-Mart. They produced 35,000 volts.
    The condition of the ignition points is critical, too. They have to be
    filed smooth and they have to be cleaned of any abrasive or residue
    from your points stone or points file and they have to be accurately
    gapped to about 0.014 to 0.015 inches.
    Since the ignition gap on the stock coils is so small, the idle mixture
    needs to be set fairly rich to start the engine. And your engine has
    set without being run for two years. The idle jets are probably plugged
    up and you will probably need to remove the carbs, open up the float
    bowls and squirt aerosol carburetor cleaner through the idle jets, main
    jets, and through the holes that the pilot air screws go into.
    Before you remove the pilot air screws, turn them all the way
    CLOCKWISE, counting the number of turns. Write that number down, then
    unscrew the pilot air screws (keep them separate so you know which one
    came out of each carb) and squirt aerosol carb cleaner through the
    holes. When you reinstall the pilot air screws, screw them all the way
    IN until they just stop turning, then turn them back out the same
    number of turns that you wrote down.
    If the engine is just mildly flooded, removing the spark plugs and
    letting the engine sit for a while will allow the gasoline to
    evaporate.
    If the engine starts and you repeatedly foul the spark plug (it gets
    all wet and oily), you may have to do all that kicking with the spark
    plugs out. I've had float valves in the carburetors stick and the
    crankcase filled up with gasoline. I had to remove the cylinder head to
    pump all the gas out...
    krusty kritter, Aug 21, 2005
  5. monk
    monk Guest
    ok so i've got the flood taken care of now, had to pump it a bit, but
    no major fumes coming out of there now. Went down to canadian tire and
    picked up a bunch of new plugs this afternoon, but still no spark.
    tried throwing my portable battery booster on the battery , still no
    luck, but it may not have had a lot of charge in it either. Gonna
    charge up the battery overnight and try it again tommorow after work.
    there is voltage on the points, and voltage at between each of the
    primary wires and ground. If my battery is weak could it be that
    theres just not enough current to get the secondary up to 20kv or
    whatever it takes for the plugs? Well I guess I'll find out tommorow
    after I charge up the battery.
    Also, i broke a couple of the old crusty fuel lines while I was
    putting the cleaned up carbs back in, do I need to use special hoses
    for that or can I just get some of that clear plastic hose from the
    plumbing dept?
    thanks again all
    ps, if you've got any good web links to a site where I can learn about
    motorcycles that would be great I'm a complete newbie and without a
    little more knowledge I think I'm gonna end up wasting a lot of time
    banging my head against a wall here.
    monk, Aug 22, 2005
  6. You need to clean and gap your points to about .014 on the high side of
    the points cam.
    A really dead battery will suck up all the juice from a battery charger
    and leave very little for the motorcycle systems if you're trying to
    start an engine. The lighting load on a motorcycle is about 100 watts,
    so make sure your headlight and tail light are off before you start
    kicking...
    Don't use clear plastic hose, you just start worrying when you see big
    air bubbles in the hose and you'll be writing messages claiming the air
    bubbles are keeping your engine from starting.
    Use motorcycle fuel hoses. They are thin walled rubber hoses.
    Automotive fuel hose is usually too thick, it will kink and shut your
    fuel supply off.
    krusty kritter, Aug 22, 2005
  7. monk
    monk Guest
    It LIVES!!
    got it working tonight, thanks for your help everyone, turns out that
    the battery needed charging/contact cleaning and the new plugs and
    away she goes, hard to believe that a 31 year old motorcycle that has
    been sitting for 2 years will just run like that. All I really did was
    clean out the carbs and charge the battery ( the old plugs might even
    had worked)
    Anyways, It runs, but I can't say how well. Being that I am a complete
    motorcycle newbie in fact a complete engine of any kind newbie. It
    sounds a little rough to my untrained ears. If I post a wma sound file
    of it here (500kb) could I get your opinions?
    Some groups have a no binary rule so I thought that I would ask first.
    Thanks again everyone,
    Now just waiting for my flywheel puller so that I can finish
    rebuilding the first bike I bought a month ago (' 81 KE125)
    and I've also got this RD350 "parts bike" to work on too... my wife is
    gonna kill me I know it...heh
    monk, Aug 23, 2005
  8. Vacuum hoses may look to be right, but don't use them. They will not hold
    up to the constant exposure to gasoline. Go to the dealer and buy some
    hose. List price is something like $1.50 a foot. The clear stuff at the
    hardware store isn't good either. It won't hold up to the constant
    exposure to fuel. It wouln't be nice if you were riding one day and you
    notice a leak and discovered that the new hose has started to dissolve.
    rj
    R. Pierce Butler, Aug 23, 2005
  9. monk
    monk Guest
    alright guys here it is, got a small website up now, have a listen to
    my rd350, and I promise to put up some pics of it and my other project
    bike soon.
    thanks,
    heres the web addy: http://members.shaw.ca/jchihonik/
    monk, Aug 24, 2005
  10. monk
    Brian Watson Guest
    Yep, sounds like and RD350 to me :) You could have given it a bit of a
    rev for us...
    Brian
    Brian Watson, Aug 24, 2005
  11. monk
    monk Guest
    wanted to wait for some input first, didn't want to rev it up and blow
    something that i didn't hear. neighbour might get mad if I start
    revving right now (it's right outside his kids window :p) but I'll run
    it up a bit tommorow after work and put that up on the site with some
    pics. Whats an acceptable rpm to rev it up to?
    monk, Aug 24, 2005
  12. monk
    Nemo Guest
    It sounds really good, Monk.
    If you really want to give the troops a thrill, after the bike is repaired
    to your satisfaction, mount the recorder on the biker and go through the
    gears for us. That will "really" bring back the memories.
    My 68 Yamaha 350 twin wasn't the RD-350. It was slightly before that and
    utilized a stamped steel frame. I used to call it the "Whaleback". But the
    engine sounded the same and it would haul ass. Loved that bike. I traded a
    guy a new guitar amp for it. I've felt guilty ever since. Another friend of
    mine borrowed it and totalled it. I guess that was instant Karma.
    Ed Cregger
    Nemo, Aug 24, 2005
