Ready to start my restore of the CB900F
Discussion in 'Motorcycle Technical Discussion' started by Diablo, May 11, 2004.
  1. Diablo
    Diablo Guest
    Well nearly ready...waiting on a fuel petcock to arrive, and will be soaking
    the gas tank in vinegar to prep it for some fuel. I had to take the helmet
    lock down to the locksmith to have a key cut as the seller is "still
    looking" for the keys...<sigh>..I got tired of waiting, and was too anxious
    to see if the motor would turn over...<LOL>...Per y'alls advice, I pulled
    the plugs yesterday and shot an ounce or so of MM Oil in the cylinders. The
    manual came last week, so I have been studying the things I'm pretty sure
    need attention, and when the moment of truth arrived, a gratifying turn of
    the key assured me I hadn't picked up a complete basket case. Bike turns
    over smartly, with no odd clanks or foreign noises. It appears all the
    lights work, horn works, and the tires have been holding air for a week
    now.....
    I've laid in a supply of fluids, aerosol cleaners, brushes, buckets, etc,
    and picked up a battery charger to keep the battery at full charge while I
    try and get this beast running again. The first order of business is
    probably going to be replacing the seals in the front forks. While I can't
    say for sure just yet, as I haven't attempted to drain the fork oil, I'd bet
    a dollar to a donut they need replacing. From what the manual says, this is
    a shop operation to remove and repress the oil seal. Any thoughts on this ?
    While I've got the front forks out, I'll flush all the nasty fluid from the
    brake lines, rebuild the front MC, and check the front pads and calipers.
    The rear needs the fluid flushed, but the MC appears to be functioning,
    though it needs a new diaphragm it looks like. I found a pretty nifty little
    tool at the parts store for bleeding lines. It has a check valve on one end
    and a fitting that slips over the bleeder valve. Slip it on, and drop the
    check valve in a container to catch the fluid, and then pump away until
    clear...Close the bleeder and your done.
    My biggest concern will be the carbs and the automatic fuel valve...Carbs
    because I can pretty much guarantee they'll need a rebuild, and auto-valve
    because if it's what went bad to start with, it'll be a pretty penny to
    replace...Everything else that even looks suspect at the moment is
    relatively inexpensive to replace. On that note, I've found that I can
    probably put a $1000.00 into it, and still be below market value...I can't
    imagine it will take anywhere near that, but one never knows....I'll try and
    throw some progress pics up on one of the websites as I go along, but if I
    can get it fired up, I'm afraid it'll be off to the MSF refresher course,
    and then do some serious catching up.
    I do have one more question, and though it's a subjective personal one, I
    wouldn't mind some input...Repaint to original or go custom ?...The paint
    isn't in bad shape, with minimal amounts of rust on the tank ( a few the
    size of a pinhead, and one about the size of a quarter)...It's the Pleiades
    Silver with Blue stripes, and the only plastic that needs paint is the front
    fender to repair the DOD stickers from being cleared for use on the base,
    and the stripes are a bit faded. I have a painter at work that shot autos
    for 30 years before he came to us to shoot wood, so I can run this through
    our shop and heat tunnel for the cost of paint....But...I can really see a
    nice purple so dark it looks black with some silver
    flames...<LOL>...Original ?...Custom ?...Any thoughts ?
  2. It's not. But it often is a shop operation to separate leg and stanchion
    in order to get at the seal in the first place.
    The Older Gentleman, May 11, 2004
  3. Diablo
    Diablo Guest
    Thanks..I may make a stab at it first, then decide if the Honda shop gets my
    money
    The Older Gentleman wrote:
    ::: From what the manual says, this is
    ::: a shop operation to remove and repress the oil seal. Any thoughts
    ::: on this ?
    :: It's not. But it often is a shop operation to separate leg and
    :: stanchion in order to get at the seal in the first place.
    :: Trophy 1200 750SS CB400F CD200 Z200 x2 ST70 DT50MX YTC#3
    :: GAGARPHOF#30 GHPOTHUF#1 IHABWTJ#1 BOTAFOT#60 ANORAK#06
    :: BOF#30 WUSS#5 http://www.chateau.murray.dsl.pipex.com/
  4. Diablo
    Charlie Gary Guest
    Diablo wrote:
    <<Snip>>
    I have one of those, too. The hose is nice because it's clear, and the
    check valve makes a good weight to hold down in the jar, but I've found
    you'll probably still bleed your brakes like the rest of us (pressurize,
    open to bleed, close, release pressure, repeat).
    <<Snip>>
    Custom paint looks great when done right, but the resale value almost always
    takes a big hit.
    Charlie Gary, May 12, 2004
  5. Diablo
    Diablo Guest
    Charlie Gary wrote:
    :: Diablo wrote:
    :: <<Snip>>
    ::: I
    ::: found a pretty nifty little tool at the parts store for bleeding
    ::: lines. It has a check valve on one end and a fitting that slips over
    ::: the bleeder valve. Slip it on, and drop the check valve in a
    ::: container to catch the fluid, and then pump away until clear...Close
    ::: the bleeder and your done.
    :: <<Snip>>
    :: I have one of those, too. The hose is nice because it's clear, and
    :: the check valve makes a good weight to hold down in the jar, but
    :: I've found you'll probably still bleed your brakes like the rest of
    :: us (pressurize, open to bleed, close, release pressure, repeat).
    ::: I do have one more question, and though it's a subjective personal
    ::: one, I wouldn't mind some input...Repaint to original or go custom
    :: <<Snip>>
    :: Custom paint looks great when done right, but the resale value
    :: almost always takes a big hit.
    :: Later,
    :: Charlie
    Thanks Charlie...
    The tool was only a couple of bucks and I figure it's just the ticket for
    flushing the lines. As far as paint goes, I hear ya on the resale
    value...It's a nice looking scoot as is, and the touchup route is far less
    work. I guess you validated my thought that I'd be better off restoring to
    original...I can always change my mind this winter when the bike will be
    mostly down anyway.
    Diablo, May 12, 2004
  6. Diablo
    rhino Guest
    rhino, May 12, 2004
  7. Diablo
    Diablo Guest
    rhino wrote:
    :: You may want to check out this site
    http://cb1100f.net/modules.php?name...5&start=0&postdays=0&postorder=asc&highlight=
    :: It has the 900f factory manual online for downloading
    :: Also much more vintage Honda DOHC info.
    Thanks mate...I am a member of that dorum as well...I have the Clymer
    manual, and unfortunately the manual in the forum is for the CB 900 Custom,
    which is slighty different than the F Series...Unless I just haven't run
    across it yet..There is a wealth of information there as you said...I have
    "just so" much time to spend researching before the fair haired ones starts
    that toe tapping stuff though...<LOL>
  8. Diablo
    rhino Guest
    Look at chapters 25 and 26 as they have the "F" Addendums, all other
    proceedures are the same as a "C'
    Good luck with your resto.... Just snowed 8" here today and another 6"
    predicted for tomorrow.
    rhino, May 12, 2004
  9. Diablo
    Diablo Guest
    rhino wrote:
    :: Look at chapters 25 and 26 as they have the "F" Addendums, all other
    :: proceedures are the same as a "C'
    :: Good luck with your resto.... Just snowed 8" here today and another
    :: 6" predicted for tomorrow.
    :: ::: rhino wrote:
    ::::: You may want to check out this site
    ::::: It has the 900f factory manual online for downloading
    ::::: Also much more vintage Honda DOHC info.
    ::: Thanks mate...I am a member of that dorum as well...I have the
    ::: Clymer manual, and unfortunately the manual in the forum is for the
    ::: CB 900 Custom, which is slighty different than the F
    ::: Series...Unless I just haven't run across it yet..There is a wealth
    ::: of information there as you said...I have "just so" much time to
    ::: spend researching before the fair haired ones starts that toe
    ::: tapping stuff though...<LOL>
    Thanks mate...will do...new petcock is due in tomorrow, and I can get into
    things in earnest
  10. Diablo
    Diablo Guest
    Diablo wrote:
    :: rhino wrote:
    :::: Look at chapters 25 and 26 as they have the "F" Addendums, all
    :::: other proceedures are the same as a "C'
    :::: Good luck with your resto.... Just snowed 8" here today and another
    :::: 6" predicted for tomorrow.
    :::: ::::: rhino wrote:
    ::::::: You may want to check out this site
    ::::::: It has the 900f factory manual online for downloading
    ::::::: Also much more vintage Honda DOHC info.
    ::::: Thanks mate...I am a member of that dorum as well...I have the
    ::::: Clymer manual, and unfortunately the manual in the forum is for
    ::::: the CB 900 Custom, which is slighty different than the F
    ::::: Series...Unless I just haven't run across it yet..There is a
    ::::: wealth of information there as you said...I have "just so" much
    ::::: time to spend researching before the fair haired ones starts that
    ::::: toe tapping stuff though...<LOL>
    :: Thanks mate...will do...new petcock is due in tomorrow, and I can
    :: get into things in earnest
    Well the beast runs !...I acquired a like new replacement seat for $4.00
    US...(where else...another one of my eBay steals...<BEG> ) and a fuel
    petcock for the gas tank...They arrived yesterday, so tonight I purged the
    fuel tank with vinegar to seal off and convert any rust in the tank,
    installed the petcock and filled it up with gas liberally dosed with
    Seafoam. All I really wanted to do was suck some conditioned fuel into the
    carbs to start them soaking prior to a good cleaning...Imagine my surprise
    when the engine tried to fire up !...This bike has been sitting for quite
    some time, and the reason I only paid $300.00 US was it "wasn't running"...I
    twisted the throttle a couple of times, and hit the starter again, and she
    caught and fired after about ten seconds of hesitation...I can't get a good
    clean idle right now, but then again the engines only run a total of 3-4
    minutes after all these months ?...years ?...no telling how long ?...I had
    set a goal of having it ready to ride 4th of July weekend !...Looks like
    I'll be on the road much sooner than that if my luck keeps holding...Front
    suspension service, rebuild all the brakes, touch-up paint on the tank and
    front fender, and a new front tire is all that is left...then lots of elbow
    grease polishing and detailing, and I'll be on the road...Well after I take
    the Rider Safety Course...I figure after being without a bike for a little
    over 30 years, I could use a refresher...<LOL>..All in all, I'm pretty
    jazzed...I had figured having to spend the better portion of the weekend
    jsut tracing down the "Won't Start" problem. Now it has hopefully become
    more of a tracing down replacement parts.
    Diablo, May 15, 2004
  11. Now there's an interesting tip. Never heard of this. Does it work? I've
    always used handfuls of nuts and bolts, swilled in petrol inside the
    tank, and haken hard, but it's a job that has to be done several times.
    The Older Gentleman, May 15, 2004
  12. Diablo
    Diablo Guest
    ::: I purged the
    ::: fuel tank with vinegar to seal off and convert any rust in the tank
    :: Now there's an interesting tip. Never heard of this. Does it work?
    :: I've always used handfuls of nuts and bolts, swilled in petrol
    :: inside the tank, and haken hard, but it's a job that has to be done
    :: several times.
    It's one i picked up in another group mate...I tried it on the gas cap
    first, and it appeared to loosen the surface rust, and the deeper rust
    became extremely difficult to brush off..The theory being that vinegar (use
    "white vinegar") is an acid and reacts with the iron oxide to dissolve
    and/or combine with it...Made sense to me, and I decided that a couple of
    gallons of ninegar was far cheaper than Kreem or POR-15....and at the very
    least it could do no harm. While it was in the tank, I also started sanding
    the outside with an electric sander which caused it to agitate. Blew it all
    out with compressed air after draining, and immediately filled the tank with
    gas dosed with Seafoam.I figure that while I'm working on everything, it
    will be good to crank the bike up and let it run several times a day, and
    then prior to getting out on the road, I'll drain the tank again and see
    what it looks like before i do the seroius break in / run in.
  13. Diablo
    Charlie Gary Guest
    Diablo wrote:
    <<Snip>>
    This has to be in the top five of the most intelligent things I've ever read
    here.
    Later,
    Charlie
    Fix the e-mail address and it will get to me
    There are about 100 different sorts of insects in Mexico that some people
    eat on purpose.
    Charlie Gary, May 17, 2004
  14. Diablo
    Diablo Guest
    Charlie Gary wrote:
    :: Diablo wrote:
    :: <<Snip>>
    :: ...Well after I take the Rider Safety
    ::: Course...I figure after being without a bike for a little over 30
    ::: years, I could use a refresher...<LOL
    :: <<Snip>>
    :: This has to be in the top five of the most intelligent things I've
    :: ever read here.
    :: Later,
    :: Charlie
    :: Fix the e-mail address and it will get to me
    :: There are about 100 different sorts of insects in Mexico that some
    :: people eat on purpose.
    Hopefully I will have forgotten all the bad habits, and can start
    fresh...<LOL>
    Diablo, May 17, 2004
  15. Diablo
    Charlie Gary Guest
    I know the course has been revamped, so hopefully it's a little less tedious
    than the Riding and StreetSkills course was. Once you get some legs under
    you, see if you can go back and take an Experienced RiderCourse. Those are
    much more fun, as they're only one day, and the focus areas on the range are
    turning, swerving and braking. They figure you already know how to change
    lanes and ride in circles. :) And turning your head as far as you can to
    look through the turns will score points with the instructors. Have fun.
    Later,
    Charlie
    eat on purpose.
  16. Diablo
    Diablo Guest
    Charlie Gary wrote:
    :: Diablo wrote:
    ::: Charlie Gary wrote:
    ::::: Diablo wrote:
    ::::: <<Snip>>
    ::::: ...Well after I take the Rider Safety
    :::::: Course...I figure after being without a bike for a little over 30
    :::::: years, I could use a refresher...<LOL
    ::::: <<Snip>>
    ::::: This has to be in the top five of the most intelligent things I've
    ::::: ever read here.
    ::: Hopefully I will have forgotten all the bad habits, and can start
    ::: fresh...<LOL>
    :: I know the course has been revamped, so hopefully it's a little less
    :: tedious than the Riding and StreetSkills course was. Once you get
    :: some legs under you, see if you can go back and take an Experienced
    :: RiderCourse. Those are much more fun, as they're only one day, and
    :: the focus areas on the range are turning, swerving and braking.
    :: They figure you already know how to change lanes and ride in
    :: circles. :) And turning your head as far as you can to look
    :: through the turns will score points with the instructors. Have fun.
    :: Later,
    :: Charlie
    Thanks mate..I intend to...The tank has been redone, and I'm waiting on the
    rubber mount for the rear...it's either forks or brakes this weekend...and
    another batch of detailing...<groan>
    Diablo, May 18, 2004
