Rear Wheel Noise?
Discussion in 'UK Motorcycles' started by Broadband Campaigner, Apr 15, 2004.
  1. Hi
    This may sound like I am hearing things, but I don't think I am.
    I have a 2001XXY Blackbird. I roll the bike out of the garage each day,
    recently I have started to hear noise from either the rear wheel, sprocket
    or chain, I don't know which. It is a click that is linear to how slow or
    fast I push or ride the bike.
    It is only a very subtle noise and barely audible over the engine
    It may have been there before and I have just not noticed it.....but.....
    Any ideas?
  2. Broadband Campaigner
    Ben Guest
    Stiff link in the chain? Happened on my last bike and sounded like a
    clicking noise when riding.
    Ben, Apr 15, 2004
  3. Thanks.
  4. Broadband Campaigner
    When you say linear - long or short delay? Long delay (IYSWIM) would
    be a stiff link in the chain. Short delay would be more likely a
    chipped sprocket tooth or perhaps several stiff links.
    Try wheeling the bike with the engine off and you might get a better
    idea. Yet better, stick the bike on a paddock stand and rotate the
    wheel by hand and you may well be able to see what is causing the
    noise.
    By the way, we post at the bottom here - below the text to which we
    are replying - having snipped irrelevant text and signatures.
    I thank you.
    Pip, Apr 15, 2004
  5. Broadband Campaigner
    Zob Guest
    I have the same bike and had exactly the same problem. What I couldn't do
    was fix it. However, even though I didn't fix it (until I changed the
    chain), I managed to dramatically reduce the noise through careful use of
    WD-40 and copious chain lube.
    Hope that helps a bit..
    Zob, Apr 15, 2004
  6. Broadband Campaigner
    Steve Parry Guest
    Have you checked the wheel in case theres a nail etc in the tyre?
    Steve Parry
    K100RS SE
    F650
    (not forgetting the SK90PY)
    http://www.gwynfryn.co.uk
    Steve Parry, Apr 15, 2004
  7. Broadband Campaigner
    Andy Hewitt Guest
    Yeah, I found exactly all that for the same noises on my FJ too. DID
    chain fitted as well. All the lubrication and twiddling with pliers
    hasn't cured it though, so it goes in for a new chain and sprockets on
    Saturday.
    Andy Hewitt, Apr 15, 2004
  8. Rope wrote:
    sounds like a text book procedure.
    Doesnotcompute, Apr 16, 2004
  9. Broadband Campaigner
    Andy Hewitt Guest
    Yes, that's what I get too, at high speeds it's completely gone.
    Andy Hewitt, Apr 16, 2004
