Rebuild tips please
Discussion in 'Classic Motorcycles' started by Ian, Jul 13, 2004.
  1. Ian
    Ian Guest
    I've just about got all the bits and pieces to rebuild my Z650 engine and
    started meself thinkin like...
    I'm using a used (within service limits) crankshaft and new bearings. Should
    I do anything to the journals? Rough em up a smidge with scotchbrite in oil
    or something? Don't laugh... I've only ever rebuilt 2 strokes before.
    Any other tips would be most helpful (don't be bleedin obvious, I know I
    have to oil things and keep crap from getting in there)
    Cheers
    Ian
    Ian, Jul 13, 2004
  2. Ian
    Mark Olson Guest
    Rough up the journals?
    Why, FFS?
    I'd just make sure everthing was spotlessly clean and lubed with
    assembly lube, or at least good engine oil.
    You might want to Plastigage the bearing clearances before buttoning
    everything up.
    Mark Olson, Jul 13, 2004
  3. ****! If you're this ignorant, why did you take it to bits in the first
    place?
    The Older Gentleman, Jul 13, 2004
  4. Ian
    petrolcan Guest
    the cont known as The Older Gentleman says...
    Surely it's better that he's asking before assembly as opposed to
    afterwards? Don't forget that not everyone has your /many/ years of
    knowledge.
    petrolcan, Jul 13, 2004
  5. Ian
    Of course. Rough yer journals up, mate. Use an angle grinder fitted
    with a Stone Grinding Disc, that'll give just the perfect roughness
    which will encourage the oil across the journals by capillary action
    and allow them to bed in perfectly.
    Don't listen to that Champ ****, he can't even scrub in a new front
    tyre.
    Pip, Jul 14, 2004
  6. Ian
    petrolcan Guest
    the cont known as Pip says...
    Champ? YTC :)
    petrolcan, Jul 14, 2004
  7. Well, yeah, but even so, asking if you should take nice shiny smooth
    bearings out of an engine and then scratch them is not the sort of
    action that requires "years of knowledge" to determine as utterly daft.
    The Older Gentleman, Jul 14, 2004
  8. Ian
    (The Older Gentleman) struggled
    to ejaculate:
    "Honing"
    Pip, Jul 14, 2004
  9. Ian
    Ian Guest
    Coz I'm too fucking tight to pay some other fucker to do it. We all gotta
    start somewhere, this is my turn
    <ooops! stocky trout syndrome, bit at the first fly cast near my nose>
    Ian
    Ian, Jul 14, 2004
  10. Ian
    Brian Price Guest
    Is your mind so closed that you don't already know the answer.
    The answer is he is prepared to open his mind to new experiences, have a go
    and seek the council of others more experienced than himself.
    Be more mindful of the real world you young impetuous padewoooon.
    Brian Price, Jul 14, 2004
  11. Ian
    Brian Price Guest
    Hi Ian
    No experience of Z650, however it is no problem having too smooth a surface
    on a rotary bearing, as long as there is a good supply of clean oil the
    bearing surface will ride on a film of oil. However on a sliding bearing
    that is not able to get a good supply of oil such as piston rings on the
    piston bore, a slightly rougher surface is used to help retain a small
    amount of oil, useful particularly at start up. It is common practice to
    rough a glazed bore by honing (not scotchbrite) this keeps the precision of
    the bore intact but leaves a surface that will retain a certain amount of
    oil.
    General tips you could observer
    Buy a manual, Haynes ones are good starting point and can be picked up cheap
    on ebay.
    Keep everything spotlessly clean, a dish washer can be useful but not on
    boil and not on rubber seals or plastic, blow of with compressed air and
    lightly spray with WD40 and keep in Tesco sandwich bags or larger parts in
    black bin bags until ready for assembly.
    By the way if you don't have a compressor, I have seen some people rig up
    something of the spare wheel of a car, surprising how much air they will
    hold and just nip down the petrol station to refill.
    Make sure all oilways are clear, squirt some oil through them if you can
    with an oil can
    Good strong well lit work bench, tape some clean cardboard to the bench top.
    When each part is ready to be assembled, lightly smear with the same oil you
    are going to use when running.
    If in doubt ask because the more you know the more you realise that you
    don't know.
    Brian
  12. Ian
    On 14 Jul 2004 06:11:29 -0700, TOG@Toil,
    OI! FFS TOG, unthreaded, crapilly-wrapped and now with no attributions
    either. Get your act together, will you?
    Ace, Jul 14, 2004
  13. Ian
    Ian Guest
    <snip>
    Thanks for the info guys, but sod the bike for now, I'm going to Portugal in
    the morning, I found out as of 2 hours ago!
    Ian
    Ian, Jul 14, 2004
  14. "Counsel", acksherly.
    New experiences = fecked bearings? Well, true, at least he had the
    intelligence to ask first. There's plenty who'd have just done something
    silly and *then* asked.
  15. This is how I see it on my newsreader - above.
    OK, so there's inadequate space between his posting and mine, but all
    the attributions are there, so what you're seeing I dunno.
  16. Ian
    to ejaculate:
    If you think the attributions are there you're seeing more than I am.
    Brian Price wrote the bit about the spare tyre, which you snipped and
    replied. That section has three _and_ four indent markers due to
    shite wrapping/formatting.
    It is awful.
    Pip, Jul 14, 2004
  17. Ian
    Works for me.
    sweller, Jul 14, 2004
  18. Right, OK.
  19. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember "Brian Price"
    Ho ho.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Jul 15, 2004
    William Grainger, Jul 15, 2004
