Reg/Rec question.
Discussion in 'UK Motorcycles' started by salad.dodger, Dec 10, 2006.
  1. salad.dodger
    salad.dodger Guest
    Right, the poor old CBX is still not charging. The voltage drops while
    the engine's running?
    Reg/rec?
    Is see M&P do CBX reg/rec units for £60, and as I'm in there ordering
    a skip full of bits[1] for the Wing, I wondered if it was worth
    lobbing one into the basket.
    Are they simple to fit?
    [1] Plugs and air/oil filters, to go with the new cambelts and new
    clutch centre plate[2] that are already in the garage.
    [2] I'm now *convinced* this is the root of the problem. Mainly cos
    everything else has been replaced. :)
    | ___ Salad Dodger
    |_\_____/_| ..87845../..23037.../..31893.
  2. wrote
    Could be. HBoL will give a few clues about where to poke with a meter
    for proof positive.
    Piece of piss and usually easy to get to.
    steve auvache, Dec 10, 2006
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, steve auvache
    <Hollow laugh>
    I await the four-page "Saga Of The Wing Reg Rec".
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in
    Performance Bikes and Fast Bikes
    Wicked Uncle Nigel, Dec 10, 2006
  4. salad.dodger
    SD Guest
    <touches wood, crosses fingers, twirls rabbit foot>
    The Wing doesn't need one, the CBX does.
    GoldWing Cambelt replacement looks good for a few lines, thobut; as
    does going back into the hell that is the clutch.
    | ___ Salad Dodger
    SD, Dec 10, 2006
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, SD
    Ahah. I mis-read. That'll be easy. Apart from the corroded nuts, the
    shonky wiring and the powdered connectors, obviously.
    Good-oh. If you could have something posted by Boxing Day, that'd be
    handy. I've not got anything else scheduled for then.
  6. salad.dodger
    SD Guest
    Ah, righty-ho.
    Seems a good way as any to spend two compulsory days off. It'll have
    to be before then, as the fourth Test starts Boxing Day morning, and I
    won't want to miss a minute of such a nail-biting contest.
    | ___ Salad Dodger
    SD, Dec 10, 2006
  7. And then the discovery that it's actually the alternator, which costs
    £££££s.
    The Older Gentleman, Dec 11, 2006
  8. salad.dodger
    Just getting at the alternator can cost £££££s.
    platypus, Dec 11, 2006
  9. salad.dodger
    SD Guest
    The testing bit in the manual looks well odd ...
    1. connect two 12v batteries in series.
    2. connect a variable (0-100 ohm) resistor across the battery with a
    50 ohm resistor in between.
    3. test lamp must go out when voltage reaches 14-15v using the
    variable resistor.
    What a palaver!
    Later, when it says "reverse direction" - does that mean just swap
    over the voltmeter connections?
    5-40 ohm one-way, >2000 the other
    | ___ Salad Dodger
    SD, Dec 11, 2006
  10. salad.dodger
    Rectifiers use diodes. Yer basic alternator produces alternating current,
    which has to be rectified to give direct current. Diodes allow current to
    flow only in one direction, which is what you're testing for.
    http://en.wikipedia.org/wiki/Rectifier
    http://en.wikipedia.org/wiki/Diode
  11. SD wrote
    It certainly sounds it.
    Could do.
    That is a diode working that is.
    steve auvache, Dec 12, 2006
  12. salad.dodger
    SaladDodger Guest
    Consensus on CBXWorld is alternator brushes.
    Looks simple, and cheap, enough.
    SaladDodger, Dec 12, 2006
  13. salad.dodger
    SD Guest
    £20 a set from Silvers. Already here.
    Should be three bolts, and two screws to fit them.
    Except.
    You can't get the alternator cover off without removing the crash
    bars.
    Bum.
    | ___ Salad Dodger
    SD, Dec 14, 2006
  14. SD wrote
    Now I buy the popcorn.
    steve auvache, Dec 15, 2006
  15. salad.dodger
    SD Guest
    I'd open the bag now, if I were you.
    The third (of three) bolts holding on the alternator cover has been
    bodged.
    Instead of an 8mm headed bolt threaded into the case, it's now a 10mm
    headed item that goes through the cases, into two manky old bits of
    sleeving, with a nut on the end.
    Right under carburettor #2.
    Of course, when attempting to undo the bolt, the nut goes round and
    round. I can't stop it with fingertips, and have no tools available to
    fit in a gap that narrow.
    Oh, fiddlesticks.
    Do CBX carbs come off one at a time, or all at once?
    Yes, I thought so.
    | ___ Salad Dodger
    SD, Dec 17, 2006
  16. SD wrote
    I have a few odds and ends of medical tools kicking around that
    sometimes come in handy for this sort of thing. In these circumstances
    I would reach for the locking arterial forceps with the carborundom jaws
    that have a lump missing, like miniature mole grips with added attitude
    they are.
    Have a nip up Clerkenwell and look in a few shop windows for ex medical
    supplies.
    steve auvache, Dec 17, 2006
  17. salad.dodger
    SD Guest
    I went to Halfords. And spent money. To no benefit.
    The alternator is off.
    It gets worse.
    News at eleven.
    | ___ Salad Dodger
    SD, Dec 17, 2006
  18. Using the patented Mavis Beacon "Hunt&Peck" Technique, SD
    <fx: Marks thread "Even More Interesting">
    Wicked Uncle Nigel, Dec 17, 2006
  19. SD wrote
    I'll get some biscuits out of the freezer especially for it.
  20. <Settles down with gin & tonic and broad smile>
    The Older Gentleman, Dec 17, 2006
