Rejoice! For He is Risen.
Discussion in 'UK Motorcycles' started by sweller, Feb 17, 2008.
  1. sweller
    Well, the dead Kawasaki GT750 that Statto left behind yesterday now runs
    and moves under its own power. The Turbo's battery, bit of petrol out of
    the Guzzi and it started first go.
    The completely flat tyre and no front callipers made for short test run.
    That and one of the header pipes isn't connected.
    So, does anyone have a clampy thing that presses the collets into the
    head and hold the header pipe in place knocking about?
    I have no idea of its proper name - three holes, one for the pipe two for
    the studs. The original one broke whilst being persuaded.
  2. sweller
    deadmail Guest
    Size? I've got one of a K100. Could check if it's the same size as the
    Z500 I suppose.
    Well, I could if I could be arsed. Enough prevarication, got to go on a
    nine mile run.
    deadmail, Feb 17, 2008
  3. sweller
    Fr Jack Guest
    Fr Jack, Feb 17, 2008
  4. sweller
    He means "exhaust collar".
    platypus, Feb 17, 2008
  5. sweller
    Correct me if I'm wrong, but that bike has a full Motad system on it,
    standard Kawasaki exhaust collars won't fit. You need a Motad one if
    that's the case.
    Lozzo, Feb 17, 2008
  6. sweller
    Oh, you're quite right about the Motad but the collars look the same as
    the ones on the Turbo. Not that I've measured them, just looked.
    I have a scrap GS550 with a Motad system and the collars on that seem to
    be the original Suzuki ones (I looked earlier today).
  7. sweller
    boxerboy Guest
    YEP
    Boxer
    boxerboy, Feb 17, 2008
  8. sweller
    Steve Parry Guest
    In
    Exhaust clamp is Kawasakis terminology
    Steve Parry
    07 K1200GT SE
    95 BMW F650
    87 Yamaha FS1
    Sukida SK90PY
    91 Kawasaki AR50
    07 VW Passat SE Estate for comfort
    www.gwynfryn.co.uk
    Steve Parry, Feb 18, 2008
  9. sweller
    Look for exhaust collar on ebay and you'll see almost exclusively the items
    we've been discussing. Look for exhaust clamp, you'll see mostly gubile
    clips and u-bolt arrangements. Kawasaki are Japanese, and can't be expected
    to know the correct term in English.
    platypus, Feb 18, 2008
