Remove carbs from old CBR600?
Discussion in 'Motorcycle Technical Discussion' started by Puddin' Man, Sep 2, 2007.
  1. Puddin'  Man
    Puddin' Man Guest
    1987 cbr600, 20k mi.
    I've got a Clymer ('87-'89) and an online scan of a Honda ('90+) manual.
    Followed the instructions, disconnected cables, etc.
    There is a brace of 4 Keihin carbs. Each carb connects to one intake
    port via a rubber or plastic hose segment with a screw-clamp on the
    port end and another at the carb end.
    I've loosened all the screw-clamps, lubed what I could with wd-40,
    etc. To my knowledge, the brace of carbs should wiggle off with
    hand pressure. I apply reasonable pressure: the carbs won't come off.
    I figger if I wail on it or apply a pry-bar, I'm gonna break something.
    Note that the brace of carbs have been firmly mounted for 20 years.
    Anybody wrestled such an alligator? Any suggestions?
    Thx,
    Puddin'
    "Mit der Dummheit kaempfen Goetter selbst vergebens!"
    -Friedrich Schiller
  2. Pour boiling water over the rubbers to soften them. It's a pig of a job,
    sometimes.
    The Older Gentleman, Sep 2, 2007
  3. Puddin'  Man
    Puddin' Man Guest
    Lordy, Mercy, that's worse than the Mikuni's on my old '73 Yama tx650.
    I *hope* the rubber monstrosities are re-usable after being
    par-flogging-boiled. :)
    Are there any Nipponese mot'cycles with real (good, durable, metal)
    intake manifolds? <g> Surely the Gold Wings ...
    Thx,
    P
    -Friedrich Schiller
    Puddin' Man, Sep 3, 2007
  4. They are. It just softens the inlet rubbers enough to give you some
    wiggle-room, as it were.
    The Older Gentleman, Sep 3, 2007
  5. Puddin'  Man
    fweddybear Guest
    Keep wigglin.....there should be a groove on the carb intake that will
    kinda "lock" it in place so it stays securely.....or you can lightly tap the
    carbs off with a mallet and a long piece of wood strategically placed (so
    you don't break anything off the carbs).
    Fwed
    fweddybear, Sep 5, 2007
