Removing tired, old and STUCK gaskets.
Discussion in 'Australian Motorcycles' started by DoinitSideways, Jan 15, 2004.
  1. Any ideas?. I thought i would finish the clutch i started redoing before i
    got the 9 a few months ago. Have finished but the old gasket is being a pain
    to removie from teh clutch cover.
  2. DoinitSideways
    Fwoar Guest
    Razor Blade - then wash the cover
    Daron
    Fwoar, Jan 15, 2004
  3. thanks daron....will give that a burl.
  4. DoinitSideways
    Steve Guest
    Steve, Jan 15, 2004
  5. DoinitSideways
    Steve Guest
    sorry forgot to mention its under the auto body section (its called gasket
    remover)
    Steve, Jan 15, 2004
  6. Really?. Interesting. Its not for gasket goo's tho is it?... This is a paper
    gasket. Just in case?
  7. DoinitSideways
    Johnnie5 Guest
    razor blade is good, you can get those $2 packet of razor blade,stanly knife
    packs and they have the paint scraper type which works well
    also think its CRC that makes gasket remover in a spray can , razor blade
    always cheaper though
    Johnnie5, Jan 15, 2004
  8. Heres a similar product from Loctite, might be a bit easier to get.
    http://www.loctite.com.au/industrial/PRODUCTS/790.htm
    Has a good description of what it will do.
    Darons suggestion is still good though, I've used a sharp knife or blade for
    years and still have most of my fingers. Just be careful with soft aluminium
    surfaces, they mark easily.
    Al
    Alan Pennykid, Jan 15, 2004
  9. Yeah, i took a small gouge out of one of the corners with a sharp knife. Its
    ok, and will still seal, but just made me worried about doing the rest of
    it.
  10. *Gets BT a large Scotchbrite*
    Postman Pat
    Pat Heslewood, Jan 16, 2004
  11. DoinitSideways
    sirprice Guest
    Why not try your local Autoparts shop and ask for the CRC gasket
    stripper. Dead easy stuff to use as its an aerosol can.
    Just don't get it on any rubber or plastic. It works great , I
    have used it heaps at work on diesel engines and for stripping
    the yellowed lacquer from aluminium parts that I want to polish.
    Dave P
    sirprice, Jan 16, 2004
  12. DoinitSideways
    My hovercraft is full of eels!
    BT Humble, Jan 18, 2004
