Reverse relays?
Discussion in 'Australian Motorcycles' started by CrazyCam, Feb 1, 2010.
  1. CrazyCam
    CrazyCam Guest
    Hi folks.
    In various automotive parts shops, I have seen (and occasionally bought)
    relays, for fitting extra stuff on bikes and cars.
    Those relays use a low power "signal" to switch on a higher powered circuit.
    Can one buy a relay that works in reverse, where when the "signal"
    circuit has power, the higher powered circuit is off, and when the
    "signal" circuit is off, the higher powered circuit is on?
    If yes, where?
    regards,
    CrazyCam
  2. CrazyCam
    Marty H Guest
    A " normal" one is a relay with normally open contacts ( contacts are
    open with no power on)
    A "reverse" one is a relay with normally closed contacts ( contacts
    are closed with power off)
    Just try you local auto elec or auto store, ask for a relay with
    Mh
    Marty H, Feb 1, 2010
  3. CrazyCam
    Pietro Guest
    Many relays actually feature both types of contacts...
    Pietro
    Pietro, Feb 1, 2010
  4. CrazyCam
    theo Guest
    Yup, no problem. Most commercial relays have both normally open and
    normally closed contacts. Any automotive shop should have a bunch in
    12 or 24 volt. Or try Dick Smith even. The Guzzi has a half dozen or
    more from the factory.
    Theo
    theo, Feb 2, 2010
  5. CrazyCam
    CrazyCam Guest
    CrazyCam, Feb 2, 2010
  6. CrazyCam
    F Murtz Guest
    Jaycar dick smith has gone to pot.
    F Murtz, Feb 2, 2010
  7. CrazyCam
    F Murtz Guest
    Forgot comma after Jaycar.
  8. Ain't that the truth . . .
    Kevin Gleeson, Feb 2, 2010
  9. And that's where things get interesting. There appears to be a
    "standard" for Automotive relays and their terminal numbering.
    Having worked in the electronics industry for the best part of 20
    years, I have no idea what drugs they were on when they come up with 30,
    85, 86, 87 and 87a.
    No really, WTF is that about? Best I could come up with is it
    originated from Bosch or Volkswagon depending on who you listen to.
    Either way, rest assured you're going to end up being more confused
    than when you started.
    John Tserkezis, Feb 2, 2010
  10. CrazyCam
    theo Guest
    Good Lord almighty!
    This is your basic 12V auto relay.
    http://www.the12volt.com/relays/relays.asp
    This layout is bog standard. It's not rocket science. You can buy the
    damn things anywhere for a few dollars. I probably have a half dozen
    in the shed. Cam needs the SPDT version, it has pin 87a.
    Theo
    theo, Feb 3, 2010
  11. CrazyCam
    CrazyCam Guest
    Ah! Right, now I understand. Thanks Theo.
    I think I have one of those fitted to the BMW, for the driving lights,
    but now must go and check that pin 87a can't touch anything!
    On the Triumph, under the petrol tank, there is a relay which feeds
    power to the headlights.
    What I want to do is put another relay onto that wire feeding the
    lights, which I can then switch on or off, but I'd like to have it
    arranged so that, if there is any problem with my switch or wiring, the
    set-up will fail to a safe, as in headlight on, situation.
    regards,
    CrazyCam
    CrazyCam, Feb 3, 2010
  12. CrazyCam
    theo Guest
    There are all kinds of relays with all kinds of pinouts. Feel free to
    point me to an automotive relay using pins 85, 86, 87, 87a and 30 that
    is different internally, or externally, to the layout shown in the url
    I provided. It will be the first different one I have seen, but I've
    only been working with these since the 1960s.
    Theo
    theo, Feb 3, 2010
  13. CrazyCam
    theo Guest
    Cut your existing live wire, connect the live end to pin 30 on your
    new relay and jumper it to pin 85, Connect the other end of the wire
    you cut to pin 87a. Connect a wire from pin 86 to your switch, connect
    the other end of your switch to ground. Done.
    When you turn on the switch the relay will activate, turning off your
    lights.
    Cheers
    Theo
    theo, Feb 3, 2010
  14. But that's the good thing about standards, there's so many to choose
    from.
    Kevin Gleeson, Feb 3, 2010
  15. I concur - but I only had 20 years experience in Auto Electrics...so I
    defer to Theo
    Fulliautomatix, Feb 3, 2010
  16. CrazyCam
    [points] Ha ha ha ha haaaah haaaaah ............
    ....err
    [looks around nervously]
    [shuffles out]
    Knobdoodle, Feb 4, 2010
  17. CrazyCam
    hippo Guest
    Shades of that Pat Paulsen quote: "I've upped my standards. Now, up yours!"
    hippo, Feb 5, 2010
  18. Jaycar or dicksmith
    internode-news, Feb 6, 2010
