Riding a 250cc on the freeway?
Discussion in 'Australian Motorcycles' started by Tony Morris, Jan 11, 2004.
  1. Tony Morris
    Theo Bekkers Guest
    "sharkey" wrote
    Ummm, you need to have a conversation with the Japanese guy on a CT90
    I met at Nullarbor roadhouse. A Cb 250 would be louxory by comparison.
    Theo
    Theo Bekkers, Jan 11, 2004
    #41
  2. Tony Morris
    Theo Bekkers Guest
    And what is the relationship between the above lot and a CB 250?
    Ummm, if you gear a CB250 higher (so it has less revs at 100 km/h) it
    probably will no longer be capable of doing 100 km/h.
    Perhaps. Or Perhaps?
    Theo
    #42
  3. Tony Morris
    Jorgen Guest
    We try to be nice about how we go about saying gofuggof, that's all. It's a
    newsgroup thing, for farks sake.
    j
    Jorgen, Jan 11, 2004
    #43
  4. In aus.motorcycles on Sun, 11 Jan 2004 13:25:47 GMT
    Does Adelaide to Brisbane on the MZ count then?
    Zebee
    Zebee Johnstone, Jan 11, 2004
    #44
  5. Tony Morris
    John Littler Guest
    Blimey it *IS* pick on JL night !
    No your weight doesn't change the gearing (yes I'll accept its a poor wording),
    if you're fat it just won't be able to pull up to the top end of the rev range
    JL
    John Littler, Jan 11, 2004
    #45
  6. Tony Morris
    Smee Guest
    Absolute twaddle.
    Get a bikini screen for it to streamline the airflow and you'll get it
    up to 110 without the buffetting.
    I owned a CD250u (same engine as the cb250 but with twin carbies)
    I weigh 85 kilos and regularly got it to 130 kmh.
    Smee, Jan 11, 2004
    #46
  7. Tony Morris
    Theo Bekkers Guest
    "Zebee Johnstone" wrote
    Undoubtedly.
    Theo
    Theo Bekkers, Jan 12, 2004
    #47
  8. That's why you see a lot of 250cc b-doubles out there, its for the fuel you
    know, and that explains why they are speed limited to 100k's as well :)
    do a quick search on power to weight ratio's.
    yes I agree, a fatter person would cause more wind resistance..
    my vtr250 handled touring quite well, I did many 1000k+ trips on it and it
    didn't complain one bit.. except when its 2 (180kg) up trying to get more
    than 120-130 out of it..
    www.mad-biker.com
    Mad-Biker.com, Jan 12, 2004
    #48
  9. Tony Morris
    I'll agree with your second sentence, but not your first. A CB250
    would be perfectly adequate for a 40km highway commute, although how
    fast it will get there is very dependent on the rider's weight. I
    hear that Postman Pat rode his to the Capital rally a few days ago?
    But then I'm planning to borrow my dad's CT90 for the trip to
    Wintersun this year, so what would I know? ;-)
    BT Humble, Jan 12, 2004
    #49
  10. Tony Morris
    That's OK, I doubt you had much beyond 150kph on a ZZR250 anyway! ;-)
    (I'm not being nasty, that's about what both my GPX250s can achieve).
    #50
  11. Tony Morris
    #51
  12. Tony Morris
    They're a fine machine, no doubt about it. I'd own one if they were
    cheap enough.
    Breaking is always bad. Mind you, correct use of your brakes is often
    a better solution than trying to "power your way out of trouble".
    #52
  13. Well, I'm not sure I've ever done more than 6 or 7 hours continuous at
    100kmh+ on the Spada (less then 2 hours if you don't ignore petrol
    stops), and I've rarely done more than 3 1000km days in a row...
    It all depends on what you mean by "long periods"...
    big (Maybe Tony is a geologist?)
    Iain Chalmers, Jan 12, 2004
    #53
  14. Tony Morris
    Johno Guest
    130 kmh? - whoa!, bet you dug up the spuds in that field in record
    time ;0
    Johno
    Johno, Jan 12, 2004
    #54
  15. Tony Morris
    Gary Woodman Guest
    (BT Humble) wrote in
    This bloke will do anything for a rally prize!
    Gary
    Gary Woodman, Jan 12, 2004
    #55
  16. Tony Morris
    Gary Woodman Guest
    205kg wet.
    Gary (just browsing the owners' manual yesterday :)
    #56
  17. Tony Morris
    JS9 Guest
    .. a Honda CB250 to get to work every day. The
    The stock CB250 is absolutely capable of this kind of application.
    If you want more punch, rejet the carb or shim the slide needle.
    http://autos.groups.yahoo.com/group/CB250_Nighthawk/
    JS9, Jan 12, 2004
    #57
  18. Tony Morris
    sharkey Guest
    Not at all: I just figured you might be busy :)
    -----sharks
    sharkey, Jan 12, 2004
    #58
  19. Tony Morris
    Dave_H Guest
    I own a CB250 and occasionally ride it on the freeway (Syd to
    wollongong) It is very happy at 80-90 will do 100klm/h and has got up
    to 110Klm. Steep hills see it drop back to 80 in 4th gear. Its revving
    fairly hard (and will happily do so all day) at these speeds. Its not
    as smooth as a 4cyl but not unacceptably coarse. There is some
    vibration from the engine at these speeds. I get tingly hands. having
    never been on a big slow revving bike, I dont know if these are less
    tiring.
    It has no fairing and a very upright (and exposed to the wind) seated
    position. This is not a problem in summer but you get very cold and
    miserable in winter. The tank is low, and thus funnels cold air up
    between yor legs and into your crotch hence frozen genetalia.
    Around town, it is an excellent bike, very maneurble but for your free
    way intentions including winter and bad weather, a comfortable faired
    bike may be better. As I said, I dont know if bigger engine is better.
    Dave_H, Jan 12, 2004
    #59
  20. Tony Morris
    Dave_H Guest
    If you are going to get a CB250 for freeway use , then get bigger carby jets
    This sounds very interesting, where does one obtain these jets from?
    and who do you reccomend to do the work?
    #60
