[QUOTE] The two plugs you speak of. were they side by side ? If so perhaps the head gasket has blown between the two cylinders :-( T.[/QUOTE] Yes, #1 and #2. I pulled #3 and #4 just then, and they're both pretty black but that's from fouling due to the troubles of getting it started in the first place. Only the first two were really oily. So I guess a compression test is definitely the next step then, as that will give some better info on what is going on. I will put the new plugs in and try running it for a short time and then check them - that should be enough to confirm if it is just those two cylinders that are a problem. Damien GPX250 -> CBR600 -> F650/R1200GS (when the $$$ are there!)
