rotor pullin-creative means
Discussion in 'Motorcycle Technical Discussion' started by b_don1, Jun 7, 2005.
  1. b_don1
    b_don1 Guest
    given an unavailabillity to aquire the right tools for the right job,
    how would one, in an emerency situation, remove the rotor off the end
    of the crankshaft of the old cb750 out in the garage there?
    b_don1, Jun 7, 2005
  2. Go to www.denniskirk.com and look up part number 28-1960 or 281960...
    That's a Motion Pro flywheel puller that works on late model CB-xxxF's.
    It's made of hardened steel, it's 18mm diameter, has 1.5mm thread
    pitch, it screws into the flywheel after you remove that 12mm bolt
    holding it on. You turn the hex end of the puller, it pushes against
    the end of the crank and POP! goes the rotor...
    Costs $10 smackeroonies.
    Oh, well, you could go down to Manny, Moe and Jack's place and look for
    an 18mm X 1.5 bolt, maybe it would cost $3 but it probably would be too
    soft and it might bugger the internal threads of your rotor, and then
    where would you be?
    krusty kritter, Jun 7, 2005
  3. b_don1
    G C Guest
    Use the rear axle. But if I could wait a couple of days, I'd order the
    tool online and do it right.
    Gopher 33 28 19N 112 01 49W
    '77 CB750K '78 CB750K
    '00 ZG1000 '96 Ducati 900SS
    **********pull 'mychain' to reply***********
    ("I've abandoned the idea of trying to appear a normal, pleasant person.
    I had to accept myself as I was, even if no one else could accept me.
    For the rest of my life I would continue to say precisely the wrong
    thing, touch people in the raw and be generally unpopular. I had a
    natural gift for it" W. F. Temple)
    G C, Jun 7, 2005
  4. You know, that axle trick isn't such a bad idea. You do have to take
    the axle out of the rear wheel and that part is time-consuming...
    I wouldn't try to pop the rotor off by tightening the axle against the
    end of the crankshaft though...
    I would slide one of my 5-pound weights onto the axle before tightening
    it snugly in the rotor. Then I would slam the weight against the head
    of the axle. The axle/weight rig would be a home made slide hammer, and
    the rotor would pop off the taper after a few repetitions...
  5. b_don1
    G C Guest
    I just tightened up the axle snug and whacked it on the end with a BFH.
    Then put a bit more turn on the axle and repeated with the BFH. Rotor
    popped off on the 3rd time. Kinda like doing a ball joint or rod end.
    G C, Jun 9, 2005
  6. b_don1
    Bummers Guest
    It hardly bent the crank more than 5 deg.
    Bummers, Jun 9, 2005
