RS Throttle change?
Discussion in 'Classic Motorcycles' started by 'Hog, Jan 4, 2010.
  1. 'Hog
    'Hog Guest
    I would like to change the integrated throttle/brake setup on the 100RS for
    two separate units. A quick action throttle and brembo master cylinder.
    The brake side is easy enough and I'm comfortable relocating the switch
    functions to a panel in the fairing. The throttle bit has had me wondering
    for a long time though. Where would one get a suitable quick action
    throttle and assuming the original cables wouldn't then fit how does one go
    about sorting that out.
    The original throttle uses two cables but I suppose a 1:2 setup would be
    possible.
    'Hog, Jan 4, 2010
  2. Have you tried googling for "quick-action throttle" -- I get lots
    of hits (and a quick glance shows prices between £20 and £140).
    Dr Ivan D. Reid, Jan 4, 2010
  3. They do.
    The Older Gentleman, Jan 4, 2010
  4. 'Hog
    Guest Guest
    Guest, Jan 4, 2010
  5. 'Hog
    Looks like the same diameter as standard but Venhill seem to have a wide
    range of possible solutions. I'll start with watchiong ebay et all for a
    Brembo master cylinder and lever. I see a lot of different cylinder
    diameters/ratios quoted, can anyone explain the subject? I can guess the
    effects in terms of lever travel and effective pressure at the pads but HTF
    do you work out what you might need.
    The RS has twin old style 2 piston Brembo callipers as fitted to many BMW's,
    Guzzles etc.
    If Ducati John manages to mate my Showa race fork radial brake front end to
    the ST4S I'm going to have a bash at fitting the OE gold Showa front end to
    the RS for a giggle. The bikes are a similar sort of weight. They both have
    large diameter axles and mating the front wheel/discs will be the biggest
    challenge.
    My dream conversion for an RS is having a slightly longer banana swinging
    arm with external shaft to squeeze in a K1100RS rear wheel running a decent
    size radial tyre.
    Hog, Jan 5, 2010
  6. IIRC many of the Bing-carbed airheads used a 1:2 setup as standard. Looking
    on the Motorworks site, there are indeed the various components available.
    I suppose yours has Dellortos, though.
    Richard Smith, Jan 5, 2010
  7. 'Hog
    Nope 32 and 40mm Bings. They are generally preferred. The ultimate was a
    Kehin flat slide conversion but that was from Ultimate Source, long since
    defunct.
    Hog, Jan 5, 2010
