RT100RT bods
Discussion in 'UK Motorcycles' started by Owen, May 28, 2009.
  1. Owen
    Owen Guest
    Does anyone want black crash bars (still in packaging) for an R100RT
    (late model)?
    Owen, May 28, 2009
  2. Owen
    Try here: www.ebay.co.uk
    Champ, May 28, 2009
  3. Owen
    Yes please. I need a set ASAP. How much mate?
    Hog, May 29, 2009
  4. Owen
    These are new you ****. Get some fucked ones from fleabay to bash
    about!
    Hog, May 29, 2009
  5. Owen
    They're one piece and bolt straight on with no rubber mounts. You'd
    have to do a lot of cutting and welding because they mount in two
    places at the bottom of the engine and one place higher up, cast your
    mind back to the K100 subframe you owned for a short while and that
    fitted to the same points.
    You'd probably get away with using them if you space then away from
    the engine a bit and they're yours if you want them.
    Andy Bonwick, May 29, 2009
  6. Owen
    They're a bit bulky to be easy to post but we'll work something out.
    Andy Bonwick, May 31, 2009
