Rust in gas tank
Discussion in 'Motorcycle Technical Discussion' started by Masospaghetti, Mar 9, 2005.
  1. I have a little Yamaha DT80 and the gas tank is rusting pretty bad -
    when I remove the petcock and drain the gasoline out, little flakes come
    out with it. The rust keeps plugging up the petcock.
    Is there a good way to stop the rusting? Or will I need to get a new tank?
  2. Masospaghetti
    G C Guest
    Depending on how bad it it rusted, you might need a tank if it is REAL
    thin. Otherwise use the POR15 system to clean and seal. I do this to
    every tank I own now. (So much easier to do it to a new tank and never
    have to worry about it.)
    Gopher 33 28 19N 112 01 49W
    '77 CB750K '78 CB750K
    '00 ZG1000 '96 Ducati 900SS
    **********pull 'mychain' to reply***********
    ("I've abandoned the idea of trying to appear a normal, pleasant person.
    I had to accept myself as I was, even if no one else could accept me.
    For the rest of my life I would continue to say precisely the wrong
    thing, touch people in the raw and be generally unpopular. I had a
    natural gift for it" W. F. Temple)
    G C, Mar 9, 2005
  3. tank?
    I have used the Kreem kit on two gas tanks. It contains a solution to
    etch the acid out of the tank, and a liquid plastic that coats the
    inside of the tank and keeps it from rusting again...
    The plastic stould stop any pinhole leaks from inside the tank, but if
    you do see leaks, you can sand paper the paint off around the leak
    and smear on some JB Weld. It's a 2-part epoxy that is fuel proof...
    krusty kritter, Mar 9, 2005
  4. I don't _think_ its too thin - it still feels heavy even when empty.
    What is the POR15 system?
  5. Sounds awesome, where can I get a Kreem kit?
  6. The description of Kreem is "Produces a tank within a tank. Cures to
    a tough elastomer compound that seals and protects any metal and some
    fiberglass tanks. Resists alcohol and gasohol and most octane boosters.
    Most gas tanks require one pint of Kreem per three gallons of tank
    capacity."
    If you can't find it on the shelf at your local motorcycle accessory
    store, you can mail order it from online motorcycle catalogs like
    www.denniskirk.com
    The Dennis Kirk price was $27.00, but you'd have to pay shipping on top
    of that, so it makes sense to call around to local motorcycle accessory
    stores first...
  7. Masospaghetti
    John Johnson Guest
    Does the same thing as the Kreem product, but made by a different
    company. We've discussed both at some length here before, so look in the
    archives for details. The short version: both products depend on
    adequate preparation and following the directions _exactly_. Both have
    their adherents and detractors. I've only used the POR-15 product, so
    can't comment on the Kreem. I've been pretty happy with POR-15's product
    lines in the past. fwiw
    John Johnson, Mar 9, 2005
  8. tank?
    Try POR-15. Their kit runs about $30 as I recall. Takes a couple
    of days, start to finish. You might want a little extra phosphoric
    acid if the tank is badly rusted. Seals small leaks and protects
    the tank's interior. I treated my tank a couple months ago and
    am very happy with the results.
    Kreem can also work well I guess but you hear occasional stories
    of Kreem liners separating from the tank surface. POR-15 sells
    another kit specifically for treating problems with Kreem liners.
    Rob Kleinschmidt, Mar 9, 2005
  9. Masospaghetti
    mike Guest
    I had the same problem with a Honda 125. There's stuff to coat the
    tank, but it costs more than the bike.
    Operating on the theory that a tank full of gas can't rust and advice
    from the net, here's what I did.
    Take the tank off, remove the petcock. Put in a handful of nuts and bolts.
    Shake the nuts and bolts around vigorously for a long time to loosen the
    rust.
    Rinse it out.
    Keep it full, so the existing rust doesn't get worse.
    Should be able to get to the point that the petcock doesn't clog.
    Use a fuel filter.
    mike
    Return address is VALID but some sites block emails
    with links. Delete this sig when replying.
    Wanted, PCMCIA SCSI Card for HP m820 CDRW.
    FS 500MHz Tek DSOscilloscope TDS540 Make Offer
    Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
    Bunch of stuff For Sale and Wanted at the link below.
    MAKE THE OBVIOUS CHANGES TO THE LINK
    ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
    mike, Mar 18, 2005
