Rust inhibitor for aluminum
Discussion in 'Motorcycle Technical Discussion' started by Smør, Jul 9, 2003.
  1. Smør
    Smør Guest
    Hi everyone,
    I've got a carburetor that I rebuilt and it's starting to rust. I
    sanded off some dirt and, subsequently, ended up sanding off some of
    the protective clear coat. What can I paint on after I have resanded
    the rust away? Can anyone recommend Boeshield?
    Thanks for the help.
    Smør, Jul 9, 2003
  2. Smør
    Charlie Gary Guest
    It may help to know you don't want hard anodizing in a case like this.
    Clear and colors don't change the size of the part, but hard anodizing
    actually results in a layer of material being built up on the surface.
    Could be good on exterior parts if dark green is what you like, but anything
    with close clearances might not work right after treatment.
    Later,
    Charlie
    fix the e-mail address and it will get to me
    Charlie Gary, Jul 9, 2003
  3. Smør
    Charlie Gary Guest
    I've never seen anybody try hard anodize on motorcycle parts. I know I
    never would. I assume the quality of the aluminum being treated has
    something to do with the corrosion bleeding through stress cracks, but maybe
    not. The only things I've ever seen the hard anodize on was aluminum molds
    for things like water skis and wake boards. Stuff you want to be really
    durable, but doesn't have to be pretty.
    For those shopping around for anodizers, it's best to ask to see samples
    before they do your stuff. Different shops have different operators with
    different ideas on how to do it, so some places have better looking parts
    than others. When you're picking up your stuff isn't the time to find out
    you're getting a matte finish on the part you wanted shiny.
    Later,
    Charlie
  4. Smør
    Smør Guest
    I purchased some Mother's polish and it works great. So when it
    reoxidizes, I just slap some more polish on? Fair enough.
    Smør, Jul 9, 2003
  5. Smør
    Charlie Gary Guest
    The perfect solution for you and many others. Getting stuff anodized can be
    a pain the first time you try it.
    Later,
    Charlie
  6. Smør
    Tom108 Guest
    After you remove the oxidation try automotive aluminum wheel paint, it
    comes in a variety of colors, clear, or aluminum color. Most auto parts
    carry it. Tom.
    Tom108, Jul 16, 2003
