Rusty Bandit Exhaust III
Discussion in 'UK Motorcycles' started by Nick, Aug 21, 2005.
  1. Nick
    Nick Guest
    I have finally got it off, one of the bolts came out after being soaked in
    Plus gas and being bashed with a small cold chisel, the other one started to
    turn after the same treatment and then snapped, flush with the head when I
    got a torx bit hammered in it
    So now it needs drilling out and re tapping........simple? yeah right
    Think I'll take it to Del Basso's, and let them have the fun.
    Thanks to every one for the advice.
    Nick
    Nick, Aug 21, 2005
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, Nick
    Yeah right. LH drill is what you need matey. Like this one here.
    Nooooooooooooo! Unless their ham-fisted spanner wankas have improved
    *radically* over the last few years.
    Bung it over here (Holwell) and I'll see what can be done.
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Aug 21, 2005
  3. Nick
    Nick Guest
    Thats a very decent offer, I am going to send the pipes off to Banditmania
    tomorrow, Can I get in touch when they are back? I am going away over the
    Bhol weekend 'till wednesday, So after then?
    Thanks again
    Nick
    Nick, Aug 21, 2005
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, Nick
    No problem. I'm off the bank holiday week, so that'd be a good time.
  5. Nick
    Eiron Guest
    Now you know why loosening and retorquing the exhaust bolts is part of
    a service for a Suzuki. I replaced mine with stainless long ago.
    You can get it out yourself with a Dremel, a variable speed drill,
    a new set of drill bits and about four hours. Or you could spend
    4 hours on your back and earn enough to pay a man to do it. :)
    Eiron, Aug 21, 2005
  6. Nick
    Or just go and buy a helicoil set which includes the drill, taps,
    inserts and tool for putting the inserts in and do the job in 15
    minutes.
    Andy Bonwick, Aug 21, 2005
  7. Nick
    Eiron Guest
    There's a certain satisfaction in getting the old bolt out without
    damaging the thread in the head.
    And fifteen minutes is rather optimistic with the engine in situ.
    If you don't start with a small drill to make a pilot hole, your main drill
    will slip and make rather a mess of things.
    Eiron, Aug 21, 2005
  8. Nick
    I don't think it's optimistic at all. If the stud was an outer one
    then 10 minutes would be realistic. The drill wouldn't slip if I
    centre punched the stud before I started and I'd be surprised if the
    stud was in anything over 20mm deep.
    I do this sort of stuff for a living so even if it does go to ratshit
    I can usually find a way to put right the damage. I often sit and
    laugh at some of the well intentioned suggestions on here and can
    predict the end results with some accuracy most times. The biggest
    problem is when things go wrong, I've got access to a full engineering
    workshop to put right my **** ups but not many others have the same
    luxury.
    Andy Bonwick, Aug 22, 2005
