Sabbatani's new brakes
Discussion in 'Motorcycle Racing' started by JWilliam, May 13, 2004.
  1. JWilliam
    JWilliam Guest
    Check out Sabbatani's new brakes, they are using a liquid magnetic
    polymer that turns to a solid when a voltage is applied. The hub is
    non rotating and by using complex castings and insulators, the wheel
    rotates about the hub and has vanes inside the fluid. When Sabb' uses
    the brake lever he applies a voltage to the polymer and the vanes are
    progresively slowed by the thickening polymer! The higher the voltage
    the thicker the polymer becomes, this has been experimental stuff for
    some years now but it was only a matter of time before someone came up
    with a use for it.
  2. JWilliam
    Chris Cavin Guest
    [snip]
    Who is Sabbatani? And aside from being a very cool concept, this type of
    brake is better than conventional disks in what way? Sounds like they could
    be a lot heavier than disks and could have heat dissipation issues. Not to
    mention needing a hella-powerful electricity source.
    -Chris-
    Chris Cavin, May 13, 2004
  3. JWilliam
    Bill Smith Guest
    GM is using it in shock absorbers to effect dampening. IIRC on the C6
    Corvette.
    Bill Smith
    Bill Smith, May 13, 2004
  4. JWilliam
    Ed Light Guest
    What if the battery goes on the blink? He's a splatter.
    Ed Light
    Smiley :-/
    MS Smiley :-\
    Send spam to the FTC at
    Thanks, robots.
    Ed Light, May 13, 2004
  5. JWilliam
    Ed Light Guest
    Ed Light, May 14, 2004
  6. JWilliam
    Chris Cavin Guest
    Chris Cavin, May 14, 2004
  7. What happens if the brake line splits open on a conventional
    system?
    Duke
    Duke Robillard, May 14, 2004
  8. JWilliam
    Ed Light Guest
    Which is more likely?
    Ed Light
    Smiley :-/
    MS Smiley :-\
    Thanks, robots.
  9. JWilliam
    JWilliam Guest
    OH!!!!!!!. . . . . . .got that wrong, sorry.
    JWilliam, May 15, 2004
  10. Who attached the conventional lines to the master cylinder?
    Who soldered the big honkin' backup capacitor to the
    electro brake controler?
    Duke
    Duke Robillard, May 18, 2004
