Safety Accessory
Discussion in 'Texas Bikers' started by topserve, Dec 1, 2003.
  1. topserve
    topserve Guest
    Here is a fairly new safety accessory that attaches to your license plate
    bolts. It doesn't require any wiring, senses when you are braking greater
    than an adjustable threshold, and flashes super bright LEDs. For more
    information go to http://users.tm.net/topserve/cycle.htm Your comments are
    appreciated.
    If you prefer, the Motorcycle Brake Flasher is also available in a 12 and 6
    volt wired version at http://users.tm.net/topserve/mbfwired.htm It has the
    same function as the battery powered version, except it draws power from
    your existing brake light (only about 50 ma).
