Sat nav for bikes
Discussion in 'UK Motorcycles' started by Jeremy, Jan 4, 2009.
  1. Jeremy
    Jeremy Guest
    OK so what's the current recommendation? Maybe you got one for
    christmas? I have the ex-Timo Medion MDPNA100 but would like to get one
    now that is designed for the bike. Sticking it inside a Tesco sandwich
    bag is decidedly sub-optimal....
    Jeremy, Jan 4, 2009
  2. Jeremy
    muddy cat Guest
    What he said, brilliant and it comes with the mounts for bike and cage.
    muddy cat, Jan 4, 2009
  3. Jeremy
    Colin Irvine Guest
    Seconded.
    The Zumo forum is full of rumours about a 660 being imminent, but I've
    no idea if there's anything to them.
    Colin Irvine, Jan 4, 2009
  4. Jeremy
    Jeremy Guest
    And before the Zumo 550...? As they appear to be just shy of £400 I'd
    be looking perhaps for its predecessor (or whatever was top dog say 18
    months ago) on ebay.
    Jeremy, Jan 4, 2009
  5. Jeremy
    Spete Guest
    "Jeremy" <> schreef in bericht
    Spete, Jan 4, 2009
  6. Jeremy
    GungaDan Guest
    I've been using a Tomtom Rider V1 for a few years. Navigation is quick
    and accurate and the route recalculation times are good. Unfortunately
    the mounting system is of poor design causing wear between the unit
    and the cradle. In my case this led to the unit continually switching
    itself off and on again when on the move as electrical contact was
    broken and remade. The bracket was replaced under warranty and it's
    been fine since. I've a feeling the design of the replacement is
    slightly different but couldn't swear to it. Also, the in-helmet
    speakers aren't very robust but (I think) these can be substituted for
    an after-market bluetooth unit.
    So in summary, if you can find a cheap one on ebay it might be worth a
    go if you're desperate to save money, but a new Rider V2 (which solved
    most of the problems of the original) or the Zumo would be a more
    reliable bet.
    GungaDan, Jan 4, 2009
  7. Jeremy
    Garmin 2610. I bought one when they sold the last of the new ones in £199
    bundles. Fitted to my bike with a RAM mount.
    It works very well IMV. No postcode search but it will find streets. The
    accompanying software for the PC, Mapsource is very good. You can get all
    of mainland Europe on a single 2 Gb CF card. It did a very good job of
    finding my hotels on last year's trip to the Alps and navigated me through
    London to a training course venue. That's in "find A from current position
    mode".
    It's not as good as the newer models for pre-programmed routes. If you are
    forced to deviate from the route, by roadworks or if the mapping gets a one
    way street wrong, then it gets it's knickers in a twist. I generally ignore
    it and start following road signs as I've a pretty good sense of where I'm
    aiming for anyway.
    As long as you use it as a navigational aid rather than expecting it to
    baby you everywhere then it is a very good tool.
    wessie, Jan 4, 2009
  8. Jeremy
    Spete Guest
    "GungaDan" <> schreef in bericht
    reliable bet.
    Spete, Jan 4, 2009
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Spete
    Unlike your quoting, which has gone to ratshit.
    Put the spliff down and sort it, you Cloggie Kunt.
    Wicked Uncle Nigel, Jan 4, 2009
  10. Jeremy
    Rajabin Guest
    Wait.........................
    http://www.advrider.com/forums/showthread.php?t=418363
    Rajabin, Jan 4, 2009
  11. Jeremy
    Rajabin Guest
    Harsh...........................
    But fair
  12. Jeremy
    GungaDan Guest
    Hmmm, what's the headset like in a V2?
  13. Jeremy
    DozynSLeepy Guest
    You could go for an upmarket sandwich bag, an aquapac for gps comes in
    around the £20 mark.
    DozynSLeepy, Jan 4, 2009
  14. Jeremy
    Jeremy Guest
    Actually I looked at these originally and (at the time at least - 2 or 3
    years ago) there was nothing of the right size and IIRC were quite
    pricy. Either that or they couldn't be easily mounted to the bike. Or
    something.
    Jeremy, Jan 5, 2009
  15. Jeremy
    Jeremy Guest
    Thanks for the offer, I'll have a look at the spec. Does it have RAM
    mounts? I already have the ball and socket parts.
    Jeremy, Jan 5, 2009
  16. Jeremy
    steveloukes Guest
    No RAM mount - it has a bracket which bolts to a crossbar type thing
    but you can remove that leaving a flat surface with 4 bolt holes to
    mount it to something else.
    Its got V8 Europe maps.
    Steve
    steveloukes, Jan 5, 2009
  17. Jeremy
    Jeremy Guest
    @r10g2000prf.googlegroups.com>, says...>
    Just noticed from the Camberley thread that you're in Farnham - I'm in
    Fleet so easy to take a look. I'll do some research and get back to you.
    E-mail in header is valid?
    Jeremy, Jan 5, 2009
  18. Jeremy
    steveloukes Guest
    Sure is - £165 if you want to collect!
    Steve
  19. Jeremy
    Simon Wilson Guest
    I use a phone-inna-pocket[1] (or a tank bag) with an Autocom headset. It
    lacks a lot of features that the rider/Zumo have for sure, but it does
    do the basic stuff which is good enough for me.
    [1] HTC TyTNII
    /Simon
    Simon Wilson, Jan 5, 2009
  20. Jeremy
    Jeremy Guest
    >, says...>
    <snip tomton rider v1 experiences>
    Thanks for your comments.
    Jeremy, Jan 5, 2009
