Sat Nav Waterproof boxes?
Discussion in 'UK Motorcycles' started by greybeard, Sep 23, 2010.
  1. greybeard
    greybeard Guest
    T'was a thread here very recently on the merits of using a decent waterproof
    box for a non-waterproof sat nav on a bike.
    Did anybody eventually come up with a really decent one that can be mounted
    and use one of the latest wide screen Nuvi's?
    I'm looking for a bigger screen, (a 21" jobby on the bike would be handy but
    then I wouldn't be able to see over it :) ) to sit on the trusty steed. I
    have a doubt though that any of these waterproof box solution will allow use
    of the touch screen whilst housed?
    Once again I'd appreciate the collective knowledge and experience of the
    group.
    TIA.
  2. greybeard
    I did eventually get my 1490T in the case I bought, but it was a
    struggle. I left it in for a couple of days & the case has stretched a
    bit so it's much easier now.
    http://www.buybits.com/product/sku_6525.aspx
    They do, the clear front of the cases is very soft. Works fine with the
    one above, & also a RAM PDA case I've got. The only problem with them
    is they don't have an anti-reflective coating, so the screen can be
    hard to see in bright sun. You can normally move them a bit to help
    with that though (which is another reason to get one that uses a RAM
    ball mount rather than a fixed mount or bar straps).
    Krusty, Sep 23, 2010
  3. greybeard
    plenty of noise on this topic over on UKGser.com
    Some suggestions:
    http://www.hein-gericke.co.uk/shop/product_info.php/cPath/23_150_
    31/products_id/8414
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230526085846
    http://www.ukgser.com/forums/showthread.php?t=223975 is a starting point.
    Register for free and you can search the archive for other options
    yourself.
    wessie, Sep 23, 2010
  4. greybeard
    greybeard Guest
    I thought that was a hard case, but now that I look closer I see what you
    mean.
    Ah good, then may well look at a cheap nuvi or similar in the very near
    future,.
    Taa.
  5. greybeard
    Bear in mind most of the Nuvis don't have an option to output the sound
    via bluetooth. Doesn't bother me as I never use the sound on a bike
    anyway.
  6. greybeard
    greybeard Guest
  7. greybeard
    greybeard Guest
    I don't use the audio for nav on the bike. I do however use the MP3 player
    through speakers on occasions.
  8. greybeard
    rick Guest
    The first time I used my pikey old Garmin on the bike (in a clear pocket of
    the tank bag) I couldn't see it 'cos of reflection and couldn't hear it 'cos
    of road noise.
    I got lost.
    rick, Sep 23, 2010
  9. greybeard
    Switters Guest
    Couple of months back, I used my Nuvi on the bike for the first time. I
    used the suction cup and stuck it to the underside of the screen, where it
    sat just above the clocks. No problems with visibility, just with
    Garmin's infernal routing, as usual.
    Switters, Sep 24, 2010
