Scottoiler - chain fling?
Discussion in 'UK Motorcycles' started by Whinging Courier, Apr 23, 2004.
  1. Those of us that use chain lube in a can know what tosh the "anti-
    fling" message is. I cleaned my wheels up lovely yesterday, went for a
    100 mile ride and now they're bloody filthy again. Not only does it look
    bad but it's dangerous as well because some of the lube creeps off the
    wheel and onto the edge of the tyre.
    So, if you use a scottoiler, have you noticed this or is it "clean wheel
    heaven"
    Also, how much does a brand new scottoiler 7 cost, about £70?
    Cheers
  2. Whinging Courier
    Steve Parry Guest
    In
    Seem to recall still having oily wheels when I had my GSXR1100 with the
    scottoiler (made worse by the wheels being white I guess)
    http://www.scottoiler.com/marketplace/default.asp?productid=28
    Steve Parry
    http://www.gwynfryn.co.uk
    K100RS SE
    F650
    (not forgetting the SK90PY)
    Steve Parry, Apr 23, 2004
  3. Whinging Courier
    Catman Guest
    I ahve to confess that I get *very* little fling from the Loobman
    thing. None of it (AFAICT) reaches the wheel itself
    www.cuore-sportivo.co.uk
    Catman, Apr 23, 2004
  4. Whinging Courier, Apr 23, 2004
  5. Whinging Courier
    Rexx Guest
    Remember to alter the rate of flow as the viscosity of the oil will change
    in warmer weather just enough to cause it to pour out, apparently.
    Rexx, Apr 23, 2004
  6. In uk.rec.motorcycles, Catman said:
    I think I threw my Loobman out. I put it all together but lost patience
    with the cable tie oil dripper bits :-(
  7. In uk.rec.motorcycles, Rexx said:
    Cheers.
    Right, I'm off for the weekend :-D
    TTFN.
  8. Whinging Courier
    Andy Hewitt Guest
    Yes it does, you can indeed adjust the flow to prevent it getting onto
    the tyre.
    Andy Hewitt, Apr 23, 2004
  9. Whinging Courier
    Whinging Courier wrote in @news.individual.net:
    the Scottoil (or whatever you decide to use) is a lot easier to remove than
    something like Motorex chainlube which makes a fine adhesive for sticking
    brake dust to your wheel.
    wessie, Apr 23, 2004
  10. wessie wrote
    Brake dust? On your back wheel?
    pffw
    steve auvache, Apr 24, 2004
  11. Whinging Courier
    Catman Guest
    Did it not work? Mines does fine
    Catman, Apr 24, 2004
  12. Whinging Courier
    Catman Guest
    Ahh. I used a 'bruce' when installing mine.
  13. Whinging Courier
    jsp Guest
    _If_ you can remember to give the little fella a squeeze at all the
    right intervals. Going on long hoons and forgetting does not go down
    quite so well.
    John
    SV650
    Black it is
    and naked
    jsp, Apr 24, 2004
  14. Whinging Courier
    dwb Guest
    It will fling oil on the wheel regardless IME - if you set it up correctly
    though it will not put oil on the TYRE. I think it's supposed to do that
    because it's getting rid of some of the crap that would otherwise stick to
    the chain.
    Oil on the wheel bothers me nothing - bit of WD40 and it wipes off easily.
    That said, you will find that everything in the region of the front sprocket
    will rapidly be covered in oil and gunk, but that doesn't seem to make much
    difference in the scheme of things.
    dwb, Apr 25, 2004
  15. Whinging Courier
    Catman Guest
    Squeeze it? WTF for? I just twiddel the little knob to alter the oil flow
    Catman, Apr 25, 2004
  16. Whinging Courier
    Catman Guest
    Ahh, right.
  17. Whinging Courier
    I believe scottoil is the same as chainsaw oil? At least, many people
    have suggested using the latter. And I can tell you that it's got to
    be the most sticky substance called 'oil' known to man. Sticker than
    Saudi crude, it is, and harder to wash off.
    Ace, Apr 26, 2004
  18. Whinging Courier
    Mark Olson Guest
    I find Scottoil to be a remarkably easy to wipe off, but I admit to
    liberal application of WD-40 on a rag to help it along. 23k miles on
    the original chain with a Scottoiler, and it looks to have plenty of
    life in it.
    Aksherly I've been using chainsaw oil since the original Scottoil was
    depleted, and as far as I can tell it's the same stuff, except there's
    no dye in it.
    You want sticky, that black PJ1 moly shite is by far the stickiest
    substance I have ever deliberately applied to a bike. I never got more
    than 10k miles out of a chain when using spray chain lubes, despite
    being fairly conscientious about applying lube every 300 miles or so.
    Mark Olson, Apr 26, 2004
  19. Whinging Courier
    Catman Guest
    On Sun, 25 Apr 2004 23:49:23 +0100, Ian < (really address
    **** *off* :)
    You're welcome
    Catman, Apr 26, 2004
