Scottoiler fitting..
Discussion in 'UK Motorcycles' started by Macie, Apr 9, 2006.
  1. Macie
    Macie Guest
    Has anyone here fitted a Scottoiler to deliver lube to anywhere
    *other* than the rear sprocket?
    Reason for asking is that this new dual injector thingy is all a bit
    Meccano and zip ties, and it would be a lot neater if it was mounted
    above the chain, and delivered oil just above and before the front
    sprocket.
    Anyone tried it, or can see any potential problems?
    Macie, Apr 9, 2006
  2. Macie
    Err, so the oil is fed to the *outside* of the chain as it runs round
    the sprocket? If so, then the oil would get flung off before it had a
    chance to penetrate the rollers.
    Pip Luscher, Apr 9, 2006
  3. Macie laid this down on his screen :
    Above and before would cause two problems...
    1. Centrifugal force is at its highest as the chain goes around the
    front sprocket, so the oil would be flung off.
    2. Oiling above (assume the outside) means that what little did stay on
    the chain would have to fight against centrifugal force to lubricate
    the side nearer the sprocket.
    Harry Bloomfield, Apr 9, 2006
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, Harry Bloomfield
    There's no such thing as centrifugal force.
    HTH.
    Wicked Uncle Nigel - To stay young requires unceasing cultivation of
    the ability to unlearn old falsehoods.
    Wicked Uncle Nigel, Apr 9, 2006
  5. Macie
    Assuming it's an o/x-ring chain, think about what o-rings are generally
    used for in an engine. If the oil's penetrating the rollers, the
    o-rings are fucked.
    The only purpose of the oil is to stop the o-rings drying out, stop the
    chain going rusty, & provide a bit of an impact cushion between the
    rollers/side-plates & sprockets. All of which would be achieved to a
    certain extent by oiling the top of the chain (especially when going
    slowly), but not as effectively.
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    Krusty, Apr 10, 2006
  6. Macie
    someone here Guest
    I thought that was the technical term for the equal and opposite reaction to
    centripetal force?
    Oh well, LAL
    someone here, Apr 10, 2006
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, someone here
    Tut.
    You just don't get the same standard of pointless argument on Usenet
    these days.
    Wicked Uncle Nigel, Apr 10, 2006
  8. Grimly Curmudgeon, Apr 10, 2006
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Grimly Curmudgeon
    Not really. If you're not going to put your heart into this, it's not
    worth doing.
  10. I can't muster the enthusiasm for it atm. Fucking knackered trying to
    drill a hole through a foot of solid concrete for an earth rod.
    GS850x2 XS650 SE6a
    Folding@Home Team UKRM
  11. Macie
    You're confusing the outer roller (which doesn't have O-rings) with
    the (concentric) inner pin & bush (which often does).
    I'd very much doubt that oil dripped onto the outside edge of the side
    plates or the outer-facing surface of the rollers will do much useful
    in rust prevention because most of it it will instantly get flung off.
    I'm also a bit confused as to why chain O-rings should dry out when
    other oil-retaining seals don't. If that were the case, surely you'd
    need to regularly oil the outer surface of crankcase seals to stop
    them drying out too, unless it's a different material.
    Pip Luscher, Apr 10, 2006
  12. Macie
    Is this a five minute argument or the full half hour?
  13. Bad form...
    It was two feet. Two fucking feet; ffs.
    GS850x2 XS650 SE6a
  14. Krusty pretended :
    Agreed, but I would add it stops the chain rusting around the contact
    area of the o-ring which in turn helps it run cooler. Once that starts
    to rust the o-rings last no time at all.
    That would be just as effective if the chain were stationary. Once the
    chain starts to move centrifugal force will fling it straight off,
    making the lubrication system little better than useless. Oiled on the
    inside, centrifugal force aids the spread of the lubricant through the
    entire chain.
    Harry Bloomfield, Apr 10, 2006
  15. Macie
    I was kinda, but more dismissing than confusing. The outer rollers have
    no effect on chain wear (stretching), so whilst you don't really want
    them drying out completely & seizing up, they're nowhere near as
    important as the pins.
    Probably when going at speed, but you'd still get more oil on there
    when riding slowly/sat at traffic lights etc than you would by spraying
    chain wax every 500 miles. Plus you get the cleaning effect of an
    automatic oiler, which is their real benefit. If any fling takes a bit
    of grit with it, it's doing its job.
    Different material, & very different conditions. Internal seals don't
    have to cope with UV light for starters.
    Krusty.
    Krusty, Apr 11, 2006
  16. Macie
    Oh, indeed, but the the chain overall will get *vastly* better
    lubrication, rust prevention and cleaning if the oil feed is to the
    inner side of the chain run. Which brings us back to my original
    point.
    My original comment was about the positioning of the oil feeds, not
    whether oilers are a good idea per se. I think that we both agree
    that they are.
    So what sun factor is Scottoil, then? :)
    Pip Luscher, Apr 11, 2006
