Scottoiler Slipperblock
Discussion in 'UK Motorcycles' started by jok, Aug 15, 2008.
  1. jok
    jok Guest
    Just my experience:
    -----Original Message-----
    Sent: 11 August 2008 11:07
    To: Tech
    Subject: Slipperblock Technical Query
    I have just come back from a 3500 mile tour across Europe (Switzerland,
    Italy, France) but my slipperblock which I fitted beforehand just lasted
    until, at the most, Calais on the way down.
    I noticed it was gone when I stopped for fuel just after Calais and I
    had to block up the remains of the pipe with a screw. For the rest of
    the trip I had to manually oil the chain which wasn't ideal.
    The bike is a Suzuki DL1000 and I had fitted the Slipperblock as per
    instructions in the middle of the lower chain run nowhere near the rear
    sprocket it was securely fastened via the pipe to the Galvanised strip
    which the pipe had been threaded through as per instructions..
    The strip was attached to one of the bolts on the chain slipper and the
    pipe was not outwith the centre line of the chain and the slipperblock
    did not in any way foul the rear sprocket on suspension compression.
    I had tested it for a few days beforehand on short runs and it seemed
    fine and I had adjusted the flow rate suitably.
    Yet it had gone by the time I reached Calais and I was left with just a
    stub of pipe (see attached pic).
    What happened?
    I see via your website this Slipperblock model has now been discontinued
    and a new version is being developed, does this imply you have had
    instances of this happening to other customers?
    I await your reply,
    John Munro
    Hello John,
    I'm sorry to hear of your experience with your Slipperblock. Your
    description (and photo) of the installation doesn't suggest any
    incompetence on your part, so. It's hard to explain what went wrong
    although another DL1000 owner did contact us who'd lost his slipperblock
    but we think this was due the conditions it was used in (sand in
    Morocco).
    With the first production run of Slipperblock kits currently sold out,
    we don't have a replacement to offer you but we'll be more than happy to
    supply you any parts you might to convert your installation to a
    conventional set up, until a MKII version is released in a few months.
    Regards, Mark.
    Mark Celino
    Technical Support
    Scottoiler (Scotland) Ltd
    2 Riverside
    Milngavie
    Glasgow
    G62 6PL
    Tel. 0141 955 1100
    Fax. 0141 956 5896
    www.scottoiler.com
    jok, Aug 15, 2008
  2. jok
    Beav Guest
    Which, although not the best, seems to have reached a more than amicable
    conclusion.
    A simple
    "I lost my slipperblock, and Scottoiler have offered to fix me up
    temporarily with a standard tube setup AND supply me with a new updated
    version FOC when they become available"
    would have been more than enough.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 15, 2008
  3. jok
    Colin Irvine Guest
    So if you find someone's post a bit tedious it's best to come right
    out and tell them, eh?
    Colin Irvine, Aug 15, 2008
  4. jok
    <coughdangerousprecedentcough>
    Pip, Aug 16, 2008
  5. jok
    Colin Irvine Guest
    Well quite.
    Colin Irvine, Aug 16, 2008
  6. jok
    Mind you, when a couple of beers better off, it frequently seems fair
    enough ....
    Pip, Aug 16, 2008
  7. jok
    Beav Guest
    I know it's very unusual for that to happen on UKRM, but I didn't feel the
    post was tedious, more like misleading.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 16, 2008
