Due to the fact that I'm planning to take my Tenere to a part of the World where it's going to be plastered in snow and road salt and I don't fancy sitting in the cold lubing my chain (and probably having to adjust it) every night it's time to give in and fit a Scottoiler. I'm not spending the extra on the electronic version but is it worth fitting the dual injector kit and is it worth fitting a lube tube as an additional reservoir? I'll be running the unit at a higher flow rate than normal to counteract the amount of road salt that's going to be thrown up so it's either go for additional capacity straight from the start or have to fuck about topping it up a couple of times over the trip. I've probably been really stupid asking these questions on here because those with a single injector will say it's perfectly adequate and those with the dual set up will say it's essential for the sort of trip I'm planning and some will say that the extra capacity isn't needed or that I should use the touring kit before checking if it's suitable for my bike but that's normal for ukrm so go for it.
