Scratched CDs.
Discussion in 'UK Motorcycles' started by malc, Dec 19, 2008.
  1. malc
    malc Guest
    A couple of my audio CDs have been scratched somehow, probably kicking
    around in the cage. What does the FOAK reckon is the best way of polishing
    out the scratches?
    Malc
    R1100RS old and tatty
    You laugh at me because I am different
    I laugh at you because you are all the same
    malc, Dec 19, 2008
  2. malc
    Cane Guest
    Could you rip and re burn them or are they unplayable?
    Cane, Dec 19, 2008
  3. malc
    CDs? In a car? How quaint.
    ogden, Dec 19, 2008
  4. malc
    www.isohunt.com
    wessie, Dec 19, 2008
  5. Mer car polish, or T-Cut. Any slightly abrasive polish.
    Chris Bartram, Dec 19, 2008
  6. malc
    simonk Guest
    Warm the plastic up a little bit by sticking it in the microwave for a couple
    of seconds, then give a quick rub with a J-cloth
    simonk, Dec 19, 2008
  7. malc
    malc Guest
    Depends on the CD player. Some they work fine in, others not so well.
    Malc
    malc, Dec 19, 2008
  8. malc
    malc Guest
    Oh that's nothing. I only bought the player this year, it replaced a radio
    cassette.
    Malc
    malc, Dec 19, 2008
  9. malc
    It only cost me a hundred nicker in Halfords a few months ago for one
    that plays MP3s off a USB stick.
    ogden, Dec 19, 2008
  10. malc
    Can't suggest anything that hasn't already been suggested, but if you
    do go for a polishing wipe method, remember to wipe the CD radially,
    never in a circle.
    Personally I'd start simply with detergent and simply get the disc
    clean, then, if that doesn't help, I'd try very fine abrasives
    (toothpaste or T-cut) and work gently - you could embed abrasives in
    the plastic if you overheat it. Having said that, ISTR Cane posting
    something along the lines that you can't polish plastic, but if the
    alternative is binning the CD, it's got to be worth a try.
    Generally, avoid wiping CDs at all, but if you must, always outwards
    from the centre. The reason is that a momentary glitch, as in crossing
    a radial scratch, won't upset the tracking servo or data (the CIRC can
    almost always fix short drop-outs in the data) but a tangential
    scratch is 'seen' by the laser for longer and thus has more time to
    throw the tracking servo and has more of a chance of making the data
    uncorrectable (though it takes a lot to do this).
    Pip Luscher, Dec 19, 2008
  11. malc
    bod43 Guest
    http://www.wikihow.com/Fix-a-Scratched-CD
    Wash it first. - I have never needed anything else.
    Make all rubbing (try for no rubbing) *radial*.
    I pat it dry with a kitchen towel since I have hard water.
    Make a copy if you can - second.
    bod43, Dec 19, 2008
  12. malc
    Eiron Guest
    You can drill 2mm holes in a CD and it still plays perfectly.
    Eiron, Dec 19, 2008
  13. malc
    Mine was 70 quid in Argos, does the same and SD cards as well
    Lozzo, Dec 19, 2008
  14. malc
    malc Guest
    £40 from Aldi for one that does USB sticks, and SD cards as well as CDs and
    MP3s on CDs. Though I have to say that the radio side of things isn't as
    good as the radio I took out.
    Malc
    malc, Dec 19, 2008
  15. malc
    Depends on the player; some are more robust than others, like portable
    ones, for example. I doubt ours could have, with standard cheap mechs,
    but we were running the focus & tracking servos in software and were,
    to put it mildly, bandwidth-challenged. The last version of our CPU
    had hardware accelerators to deal with the integral term (we used a
    PID algorithm) but the bloody things didn't work, did they? Then MP3
    became the Thing To Have and shortly afterwards the money ran out. We
    could certainly play across a 1mm strip of electrical tape and
    eventually sorted the standard Heavy Fingerprint pattern: that was
    quite a challenge because it was a couple of centimetres wide.
  16. malc
    The most important feature for me was the buttons all light up red to
    match the rest of the dash.
    ogden, Dec 19, 2008
  17. malc
    I found that with mine, Radio 1 reception is bloody awful compared to
    the factory fitted Blaupunkt I had in my Micra
    Lozzo, Dec 19, 2008
  18. malc
    Mine reflected the display in the windscreen, which was bloody
    distracting at night.
    Lozzo, Dec 19, 2008
  19. malc
    boots Guest
    Sounds like a step in the right direction.
    boots, Dec 20, 2008
  20. malc
    Eiron Guest
    Because I can. The theory is that the CIRC will fix 2.4mm gaps in the data
    so I wanted to test it. Obviously not on an important disc.
    Eiron, Dec 20, 2008
