Well, today was very wet and very dry in equal measure. Wet as it tipped down as I tried to work on the Jag so dodging between heavy showers prolonged the job but the end result was a very dry bearing. I mean no grease at all. I cleaned up one of the races and it span quite freely - I may have even got away with re-packing them with grease.... [URL]http://www.flickr.com/photos/47192463@N03/sets/72157623462142046/[/URL] It's lunched the spacer so the end float is all over the shop so that needs replacing but I can drop the hub, bearings and UJ in a couple of hours to set it. UJ was fine but hub spacers and shims were fucked. It's a bit of an involved job to set the end float accurately but parts are cheap(ish). Damaged bit in the picture is £25 and the shim/spacer is £6. Just need to calculate the size I need. Oddly, the other side had grease but will get a strip and clean.
