Screwed on a Shoei Raid
Discussion in 'UK Motorcycles' started by ellisgm, Jun 17, 2005.
  1. ellisgm
    ellisgm Guest
    Hi,
    I've got a 2 year old Shoei Raid helmet, and have lost the upper
    plastic screw that holds the visor mount to the helmet.
    Has this happened to anyone else? If so, did you find a replacement
    screw, use superglue, or buy a whole new visor mounting. How much does
    the mounting cost?
    Cheers.
  2. ellisgm
    It should have come with spare screws - all Shoeis I've had in the
    last fifteen years (3 off) have done so. Usually in the zip-sealed
    plastic bag with the instructions and warranty card.
    Failing that, get down to any half-decent dealer - I'd be very
    surprised if anyone would charge you for a replacement screw.
    As it happens, I broke the mounting plate and screw on my Shoei exCeed
    recently, but managed to cannibalise it's predecessor, which I'd been
    keeping for spares. Then again, maybe it's time for new lid anyway as
    that's not the first time it's been dropped...
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Jun 17, 2005
  3. ellisgm
    ellisgm Guest
    Ta for the replies.
    Nope - I didn't get any spare screws in the plastic bag when I bought
    the helmet :eek:(
    I've emailed Shoei Europe, and they told me to use the "dealership
    locator" on the web site. I got two Shoei dealership "hits" nearby in
    Crewe. The first dealership said we don't sell that many Shoei helmets,
    and use the other dealership. The other dealership (where I originally
    bought my helmet) said they don't sell the screws by themselves, only
    as part of a kit - probably the entire visor mount.
    I'll find another dealership...
  4. I bought some from http://www.bykebitz.co.uk a few years back.
    Boots Blakeley, Jun 17, 2005
  5. ellisgm
    zymurgy Guest
    They do get loose. Best to check & tighten them up periodically.
    I fear this advice may be a little late for you ;-)
    Lozzo of this parish deals in lids, and owns about 7 at last count. I'm
    sure he will be able to liberate/obtain one on your behalf ..
    P.
    zymurgy, Jun 17, 2005
  6. ellisgm
    ellisgm Guest
    My screw fell out while I was on holiday in France. Turns out I got
    "over excited" about screwing, and tightened it too much.
    Had a look at http://www.bykebitz.co.uk, but they seem to sell helmets,
    not the screws.
  7. ellisgm
    gomez Guest
    And I have a perfectly fine Suomy Gunwind sitting on the shelf because
    I refuse to pay nearly £40 for some replacement visor brackets which
    broke because: a) They are of a cheap and nasty construction; and b)
    because I is a clumsy ****.
    I am down to only three usable helmets at the moment :(
    gomez, Jun 17, 2005
  8. ellisgm
    Eiron Guest
    Mine didn't.
    Should I return to that shop, whose name I have forgotten,
    in Farnborough and ask an assistant for a screw?
    Eiron, Jun 17, 2005
  9. ellisgm
    says...
    Make that 47 :) I have a few odd visor plate screws here if the OP
    wants one. I can't promise it will fit though.
    What the OP needs to do is go to any shop that sells Shoeis and order a
    screw kit, they cost next to bugger all and any Shoei dealer will be
    able to supply one.
    Lozzo, Jun 17, 2005
  10. ellisgm
    Trevor Guest
    If you do make sure you take your own vaseline otherwise it may chaff ;-)
    Trevor, Jun 18, 2005
  11. Try calling / visiting, the screw I obtained was from a jam jar of
    useful bits so unlikely to be referred to on the webshite.
    Boots Blakeley, Jun 18, 2005
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, Boots Blakeley
    Paging WC!
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Jun 18, 2005
  13. ellisgm
    Ian Blakeley Guest
    FROYRNB
    Ian Blakeley, Jun 18, 2005
