Second neutral??
Discussion in 'Australian Motorcycles' started by GB, Jan 24, 2004.
  1. GB
    GB Guest
    As y'all know already, 2003 model ZZR250. Approx 2750Km on
    the clock (yes, I know, I've been riding it a lot!). Last
    oil/filter change at 1000Km, next book change at 6000Km,
    next planned change at 3500-4000Km. (Not even sure that oil
    has anything to do with the price of fish) Seems to have
    developed itself a 'second neutral'. Don't remember where
    it is, but I think maybe between 2nd and 3rd, or 3rd and
    4th. Only finds it on gentle upchanges (like when halfway
    through a corner from a standing start, and rolling with
    the clutch in to let the car in front get away a bit), and
    only when I really need to be concentrating on something
    else right then.
    Is this normal behaviour, or an oddity? Am I right in
    assuming that gear selection is something that is cast
    in, well, iron and that there's nothing to adjust to make
    it go away? (It's not a particular problem, just that
    it's happened a few times now, and seems kinda wierd.)
    TIA,
    G
    GB, Jan 24, 2004
  2. GB
    Johnnie5 Guest
    fix that lazy foot of yours
    Johnnie5, Jan 24, 2004
  3. Is this normal behaviour, or an oddity? Am I right in
    yep, give it a good whack through rather than a gentle 'snick' and pull the
    clutch in all the way
    fulliautomatix, Jan 24, 2004
  4. GB
    Sprint Guest
    Try adjusting the position of the gear lever at rest, so that it hangs a
    little lower, and hence gets more 'throw' when you upshift. Experiment with
    the position and see if it helps alleviate the problem... good luck.
    Sprint :)
    Sprint, Jan 24, 2004
  5. GB
    Dave Guest
    i get the same thing every now and then on the 600. must be a ZZR trait. it
    happens rarely tho.
    Cheers
    1991 ZZR 600
    1991 EB Falcon wagon
    1969 ZC Fairlane
    admin@loopback $LOGIN@localhost
    $LOGNAME@localhost $USER@localhost $USER@$HOST -h1024@localhost
    Dave, Jan 25, 2004
  6. tsk tsk..clutching through a corner... the text books say thats baaaaddd...
    But, i wont be a hipocrit, (spelling??). However, try what sprint mentioned
    and remember to change the gear... dont caress it.
    DoinitSideways, Jan 25, 2004
  7. Hi G.B,
    The low power (relative to bigger bikes), probably means that the teeth on
    the gears do not need to be greatly undercut, like a sportsbike. So it would
    seem to be easier to slip into a false neutral under light load. Also the
    tension of the drive chain would be a factor as well.
    I seem to remember my ZZR 250 having a few missing cogs, I think.
    The other choice is to get thicker boots, or adjust the selector downwards,
    and push harder/longer.
    Rob.
    Getting Slower & Slower !, Jan 25, 2004
  8. GB
    FuTAnT Guest
    You know how they teach you to hold tension on the shift with your foot from
    1st to 2nd .. well .. what they didn't tell you is that you should do the
    same thing through all the gears if it's a bit suspect. Other than that,
    play around with the adjustment for your foot so you've got a nice positive
    *snick* on the upshifts, and make sure you're pulling the clutch all the day
    in.
    I've got over 5000km on my late 2003 CBR954 .. so you're not riding enough
    btw!
    Cam
    '03 954
    FuTAnT, Jan 25, 2004
  9. GB
    Wocka Guest
    My 01 ZZR250 used to do that as well, But really it's the rider not forcing
    the selection enough, I used to get it between 5th and 6th.
    Wocka, Jan 26, 2004
  10. Tsk, time to split the cases.
    Though I'll buy it off you for 1200.
    Hammo
    Hamish Alker-Jones, Jan 26, 2004
  11. Tsk, time to split the cases.
    I now remember when i first posted to this group with a bike problem i took
    this advice seriously and was ready to split the cases before another motian
    (mick) came and checked my bike out to discover that i needed to learn how
    to adjust tapets...
    Josh - Southport, QLD
    ('81 GSX250 --> '83 VT250--> '85 GPz600R --> '98 ZX9R)
    Remove _baffles_ to reply.
    Hammo
    [/QUOTE]
    DoinitSideways, Jan 26, 2004
  12. GB
    sharkey Guest
    There's plenty of good advice around here, it's just that there's
    plenty of bad advice too. Anyway, on the Spagthorpe Dachshund
    you _did_ have to split the cases to adjust the tappets ...[1]
    -----sharks
    [1] it was a transverse-crank horizonatally opposed twin, but with the
    heads together in the middle (for ease of carburetion) and the cranks
    at front and back. The dual exposed primary toothed belts provided
    sufficient grip to power the Dachshund through the deepest snow, despite
    its great length and squat stature ...
    sharkey, Jan 27, 2004
  13. GB
    Nev.. Guest
    Hey look, Josh worked out how to attribute and how to post in context. Wonder
    when he'll find out about trimming.
    Nev..
    '03 ZX12R
    '02 CBR1100XX
    Nev.., Jan 27, 2004
  14. GB
    Theo Bekkers Guest
    "Nev.." wrote
    He's too hirsute?
    Theo
    Theo Bekkers, Jan 27, 2004
  15. GB
    Theo Bekkers Guest
    "sharkey" wrote
    For a really stupid tappet design, it's hard to surpass the early Ford
    Prefect. My father-in-law had one of these with a sidevalve motor.
    This motor did not have any mechanical tappet adjustment. The valve
    stem had no cap and collet system to hold the valve springs on either.
    The valve stem had a ball shaped end and the spring cap had a slot in
    it so you compressed the spring and slid the cap on the narrow part of
    the stem. To enable this ball-ended valve to be removed from the
    engine, the valve guide was split and had to be driven out of the head
    to enable valve removal. Once you removed the head, the valve spring,
    and driven out the valve guide, the tappet clearance was adjustable by
    means of grinding the ball end of the valve.
    Ford ingenuity by the one bean, two beans, three beans method.
    Theo
  16. He's too hirsute?
    What The??
    DoinitSideways, Jan 27, 2004
  17. I now remember when i first posted to this group with a bike problem i took
    to adjust tapets...[/QUOTE]
    Welcome to harsh week Josh...
    big
    Iain Chalmers, Jan 27, 2004
  18. Welcome to harsh week Josh...
    But it was 2 years ago when i had the problems and was told to split the
    cases. Ah well, now im slightly wiser...
  19. GB
    sharkey Guest
    I'm genuinely aghast.
    -----sharks
  20. GB
    Theo Bekkers Guest
    "sharkey" wrote
    Makes OHC bucket and shim look fairly simple. don't it?
    Theo
